I'm seeing much higher minimum fps, and less stuttering, in quad crossfire.
Where are you seeing less stuttering and on what setup please.
Just chalked up a very good score @4K using the Sleeping Dogs bench.
Don't be shy then.![]()
I will post it in the morning when I get in from work. It is quite a bit faster than the Titans.
As to the problems I am having with the drivers, I have decided to write it off to the monitor being an older design and basically crap. The problem with 4K is it is a new thing with lots of teething problems. There is also a lack of user experience where 4K is so new. The more people highlight and discuss the problems the better. I would never recommend a MST 4K monitor to anyone after the problems I have had.
Sorry to hear about the monitor problems. Seems a shame as you got a expensive model too. What are you going to do about it?
I really think we should have a 4K sticky thread that people can post in with all things graphics related that people have problems with from connectors to drivers to graphics and vram or anything else related. It may even help Gibbo shift more gear.
Looking forward to it.
4K is 290 territory, providing they don't run out of vram.
Realistically multiple r9 290 territory if you want playable frame rates![]()
I solved my Eyefinity issues - by just going back to 14.4.
I knew going back to Amd I'd spend about as much time enjoying playing games as I did trying to get things working.
Their drivers are still pretty pants, all things considered. Sure, performance gains are good, but they usually end up breaking one thing when they fix another.
