You can get a more tube style mod, no problem. The problem with them is they are roughly the same price, but you will be required to purchase separate batteries and charger. This is not a problem, of course, but will be more expensive.
The SVD is a good device : http://myepack.co.uk/mods/itaste-svd-express-full-kit.html
Or a Vamo V5 : http://myepack.co.uk/mods/vamo-v5-full-kit-ss.html
These kits will come with reasonable batteries and a decent charger, so should set you up quite well.
I haven't had an SVD myself, but have had a couple Vamo's.
You could go straight into mechanical mods, but that would probably be too steep of a learning curve, as you have to get into battery safety, and ideally coil rebuilding too.
Again many thanks, that Vamo V5 looks good, though not sure about what "clearomiser" I should go for, theirs quite the selection in the drop down menu.
Now..erm...liquids....what the hell im I looking for here lol.
