my setup
PC -> Musical Fidelity V-DAC -> NAD C 316BEE -> Wharfedale Diamond 122 or Sennheiser HD650s
I also got Beyerdynamic DT770s that I use at my internship and a pair of sennheiser IE7s.
Might post some pictures later
Looking good, Ryan. As per prior conversations, I'd be very happy to demo and then more than likely take them off your hands when I return!
(Also, do I spy DT770s in the background of the 2nd shot?)
I reckon you will love them! That air and space with some slight warmth will get you! LolMan, I have wanted the IE80s for such a long time now
Guess I'll have to make do with 2nd hand IE8s (when I do upgrade), they're more inline with my budget![]()
Here is mine.
Schiit Bifrost with upgraded usb & uber board fitted > Schiit LYR 2.
Headphones Sennheiser HD650's & AKG 702 65th Anniversary Edition's.
Ah nice one Mason, good to see some speakers![]()
I had the HD 650 and Annie's too.
How do you find they compare? I personally found them too similar to each other. I found the 65th had more body and emotion to the vocals and the vocals sounded more intimate to my ears. I definitely found the 65th better! The 650 though is perfect for nighttime listening as it has a more smooth treble giving it a polite sound.
Curious about your opinions as not many own both!
Similar to your points above as they both have there good & bad points but it's been a hard decision, but looks like I will be selling the HD650's in MM as I have just bought these
