*I am uploading temp images until I can access some better/HQ ones*
As an avid build log reader, theirs nothing worse than large chunks of the build not being documented, for many reasons I don't have as many images as I would like.
I would like to thank Phil for the late last minute  help with some additions!
This is something I made in sketchup, I wasn't happy with scale of the MSI tail and hands when placed, I opted to use the Circuit Design from the MSI Gaming range packaging.
case Feet are something else I had overlooked, stock of the ones I wanted was issue [...again]
 Thinking outside of the box I opted to used some spare Alphacool res tops and selections of nuts/bolts
I set about adding some additional cable routing for the 24 pin and SATA ports.
Next I began sleeving the cables, I must state I really wished I had
1. Started sooner
2. Ordered even spare terminals!
I can say with confidence It's no easy feat to sleeve. even after mass research I found the cable towards the end much more to my liking, as with everything you have little experience with that is.
The added challange being that the CM power supply uses a rather unusual wiring method. The 24 pin actually bridges off to 10 and 18 pin connector.
So rather than double wire to one terminal approach I used the lutro0 solder guide. Results where mixed and I will redo them soon!
Before powdercoating I mocked up the frame with some spare vinyl and photoshoped it, right up until the last second I was still unsure to go Black or white.
White just seemed to work better
Mock up with the side door [Not fitted yet]
Last minute deleiverys to wire up all the fans and LED's
This is where I was at one point
 at 5.30 AM fixing things
Now sadly I don't have any decent images from Insomnia...other than these
Mid filling...working on the air bubbles
Within and hour or two of setting up. I faced an issue of no display, then no power to the system. Due to extremely restrcited work space their was little I could do. The system was moved to another part of the exhibit, on onto a funky oil drum of sorts. The system that was wired up into my spot after also faced power issues and blew their hard drive. At this point I was very concerned at just how much damage had been done
Things went south that night as we took the rig back to our hotel, in attempt to getting it up and running. We where struck down with food poisoning and after missing out all of Saturday, we hit the road and traveled 230 miles back to get some much needed rest.
I've spent the last few days getting back on my feet and getting the rig running again. Nothing major was damaged... thankfully.
These are the only images I have from my phone atm
I will take some HQ shots of the rig and have them online ASAP!
While it wasn't the most ideal outcome I still had a blast and will be back more at the next iseries event
