What are peoples opinion on this model?
http://www.modelsport.co.uk/ftx-van...ss-buggy-rtr-waterproof/rc-car-products/40388.
Its quite a bit above my budget at the minute though.
I have that exact car and I can tell you somthing for the money I think its a bloomin bargain.
I needed to upgrade the front thingy that the suspension connects to for a upgraded carbon fibre one that was £20 but thats all.
It is rapid, to fast almost, good fun on grass and stuff and it quite robust.
wife is going to kill me
I spent about £250 on one and smashed it up on my first outing with it. They're really not made for flying through the air.
I like that a lot
2 tanks is plenty stationary.
I think with mine I did half a tank on idle, following half 1/4 throttle. Then work up though about 4 tanks to WOT.
Oil out the exhaust means it's running rich, which is standard from the factory. As you run it in more you eventually lean it out![]()
Cheers for the advice. Managed to take it out on a bit of private road today and went through a few more tanks gradually building up the revs in short bursts at first then longer ones.
Wasn't the cleanest bit of road to use and the driver was a bit of a novice too so it's got that authentic 'used' look to it now. Seems to really howl once you let it rip and stops almost instantly
Will keep an eye on how it runs and try leaning it off a little bit, when I popped into the shop today where it was originally bought from they said it wasn't crucial but it was advised on the hpi DVD which came with it.
