What are your best game mods?
Is there an equivalent of this for Skyrim? OOO was great and i just can't be bothered with installing 10+ mods
SkyRE off the top of my head, although I don't think skyrim needed the scale of overhaul to the same extent oblivion did - so there is nothing really comparable to OOO for skyrim.
My little lad has Minecraft - anyone recommend some mods for a 10 year old player (ones easy to install too!!)
Ta
If you spend a bit of time installing Minecraft Forge, then you can just drop forge compatible mods into the forge directory. My little 9 year old like Animal Bikes mod, loads of different walking/flying mounts
I have no idea what you just said, but thanks anyway. :p
forge is like a master mod that makes modding easier. there's plenty of guides out there and its much better than trying to manually install mods [something i've never successfully done]
if you want ultimate ease you can download tekkit or feed the beast [ftb] they're mini applications that allow you to choose from a range of modpacks that are pre-made.
My own unreleased (unfinished) mod for Quake 2 that basically turned it into left 4 dead, meets guildwars meets dishonored but in the strogg setting.
There were a lot of q1-3 mods that were outstanding.
