As title!
I bought the below bike late last week and had a really good run out today, why I haven't done this sooner I don't know, my bike gave way again last week so I decided to replace it rather than repair it this time!
For what I'm using it for its perfect, and also opens new doors too, looking forward to getting out on this bike again!
Thanks for looking, any tips then I'm all ears
Thanks for looking.
Direct Link: http://imageshack.com/a/img540/5821/c7b96f.jpg
Thanks for looking.
PRODUCT SPECIFICATIONS
Features
Ride the fastest wheel that fits with Smart Wheel Size
Ride-tuned aluminium frame is XC light, mountain tough
Extended size range gives you a better fit for a better ride
Backed by Trek's limited lifetime warranty
Frameset
Frame Alpha Silver Aluminium w/semi-integrated head tube, rack & mudguard mounts, G2 Geometry on 29ers
Front suspension SR Suntour XCT w/coil spring, preload, custom G2 Geometry w/51mm offset on 29ers, 100mm travel (14.5": 80mm travel)
Wheels
Wheels Formula DC20 alloy front hub, Formula DC22 alloy rear hub, Bontrager AT-550 36-hole rims
Tyres Bontrager XR1, 29x2.20" front, 29x2.00" rear (Bontrager XR2, 27.5x2.20")
Drivetrain
Shifters Shimano Altus M310, 8 speed
Front derailleur Shimano Altus
Rear derailleur Shimano Altus M280
Crank Shimano M131, 42/34/24
Bottom bracket Sealed Cartridge
Cassette Shimano HG31 11-34, 8 speed
Pedals Wellgo nylon platform
Components
Saddle Bontrager Evoke 1
Seatpost Bontrager SSR, 2-bolt head, 27.2mm, 12mm offset
Handlebar Bontrager Riser, 25.4mm, 15mm rise
Stem Bontrager Approved, 25.4mm, 15 degree
Grips Bontrager Satellite Plus
Headset 1-1/8" threadless, semi-integrated, semi-cartridge bearings
Brakeset Tektro M290 hydraulic disc brakes
Upgrades from Marlin 5
100mm fork
24-speed drivetrain
 Rolls over rocks and roots easier due to the wider circumference.
