***The Vapers Lounge***
Status
Not open for further replies.
How realistic should I be about flavour, is it just the Strawberry is pretty bad, or was I expecting to much from these?
Just ordered the Scopes Apple Tart but dropped it down to 6mg to see what thats like.
Looking to order a couple more though.
Going through that list VR, but with some strange names its kinda hard to know what you are getting.
Went for a couple from Vape King, to try another maker.
Went for Monkey Jizz and Jester Juice ( dont ask, looked interesting) at 12mg, so thats a good mix coming, bound to find something in all of them right?
The hardest part is finding a juice you like. Taste is subjective as they say. :)
Also dont forget, Steeping can make a big difference. ;)
Monkey Jizz is great, one of my faves. Jester Juice ain't bad either, along with MDV666, Kings Custard.
For me its easy, fruits or custards. :D
Another option is these guys....
http://www.smokerainbow.com/
Aftet not spending anything for ages apart from heating coils, I have had a little splurge (all uk based sellers)
1 x vamo v5 (full size spare)
1 x Kayfun lite
1 x Omega RDA dripping atty - fancied something different
assorted kanthal and cotton wool
I spent two years building my own coils and then enjoyed the convenience of just using 3rd party systems as I couldn't be bothered with the faff. But the Clapton coil has re-ignited my love of fiddling, so 80 quid later.... :p
Cant wait for it all to arrive
Nice selection. :)
Looking for an atomizer to replace my Mini Protank 2 as I have cracked the glass and I am not 100% sure about the flavour from my Mini Protank 2. I am into building my own coils if this helps.
Otherwise I will just get another Mini Protank 2.
edit. Looking for something of equal size.
Have been trying an inordinate amount of different juices over the last few weeks, still can't seem to wean myself off Dekang RY4 though. In a Glass Vivi Nova @ 7 watts it's divine! I still like to huff some ABC (Custard) but it get's too sickly after a while.
Thanks, will check it out.
I need something portable for when I am out and about. However something like a Kayfun Lite is starting to look appealing with something like a Vamo V5.
Are clones something to stay clear of?
Depends on your point of view.
https://www.fasttech.com/p/1700500
That is the best clone Kayfun I have had. I now have 2.
But my genuine is great too. Machined a little better, and I get to feel all superior and stuff.
Got home and stripped it all down and cleaned it out of the strawberry, put in what came with it which was the Raspberry, went for it cause of the smell straight from the bottle just seemed nicer than the Strawberry, big difference, much nicer, still not what im really looking for, but just glad to at least taste a difference, think 18mg is too strong, want something a bit calmer so glad I ordered lower.
If Say I leave it to Steep over night, am I literally just leaving the lid off the bottle it came in?
I'd steer well clear of clone batteries, everything else is worth a shot as the worst that could happen is you end up with juice all over the shop or knackered coils. The batteries though, no.
I'd probably avoid Vamo clones (if they exist) I doubt the circuitry will be up to much, the genuine V5 is great though, much prefer the Kanger K-Simar (you can get it on myepack too).
All Vamos are clones? There isn't actually a genuine maker of the vamo (some COULD argue KSD I guess, but that's debateable).
But yeah, batteries are something you want to keep clear of clones, but mods and atties are fair game. Not all clones are equal though. You want to try and keep to good quality clones, with both mods and attys. The Infinite Kayfun clone is certainly among the best.
Here is a UK retailer for that one, same as the chinese one above, but a tenner dearer (£13.90 when you count p+p) and a fortnight quicker : http://www.angelfiremods.co.uk/store/p125/CLONED_KAYFUN_LITE_PLUS_INFINITE_V2.html
Right I need a new mod, as good as my SVD is I miss the flavour that I was getting from my clone.
Budget is about £30, got batteries, am I right in thinking that a Nemisis is the best bang for toke at that price?
If your looking solely for a mech mod then the Nemesis isn't a bad choice, but for that price there is a few others out there for you to consider. Its what you like the look of at the end of the day. :)
https://www.elegantvapour.co.uk/mods/mechanical
http://greyhaze.co.uk/collections/ecig-mechanical-mods
http://www.m-vapes.co.uk/store/c2/Mechanical_mods.html
http://www.onestopmodshop.co.uk/index.php/mech
http://www.vapegeek.co.uk/
That said, clones are bad m'kay. ;)
Another quick question..
With my Mini Protank II on it's way out, I am looking at getting either Evod Glass or Aerotank mini. However these are both dual coil. I have recently learnt to coil my own Mini Protank which is single coil. Dual coil seems like a lot of effort, so could I just coil the Evod glass or Aerotank mini as a single coil?
Unsure about the EVOD but kanger dual coil verson 3s are perfectly rebuildable and actually work really well with a microcoil. They are just a little bit more fiddly. The missus is using them in an aerotank mega and it vapes really well. Ill imagine that the small size of the aerotank mini will be really good if the protank mini is anything to go by.
Thanks. So much out there I keep changing my mind.
I want something small and portable, so was thinking of mini aerotank and either just a normal evod battery or something like an iTaste VV.
Then something more menacing like a Flogger V4/ Kayfun Lite+ / Kayfun 3.1 with a Vamo V5 or Nemsis.
Status
