Cheers fellaYou will be fine with 16gb of ram for playing games. It wont break anything unless the ram is dodgy or mismatched, it wont make a blind bit of difference to the performance of any game right now.
yep, all it does is mean you never have to worry about not having enough. admittedly there's been very few situations i've reached over 8GB of usage but its nice to know the rest is there
I have 8GB and are getting by just fine although admittedly I don't have any of the games the OP listed above.
I am a bit behind the times, so is 16GB the new standard for gamers these days then ?
I belive that's a Classic system nowI have 4GB RAM and play modern games just fine (Q9550, 2x6970).
No 8GB is fine. I want to stop drinking and get back in to photo editing, my system died killing 4 out of 10 drives (only 6 connected) so I brought a new SSD (512) 4790 & hero MB. The week before I brought a Benw 144mhz monitor.I have 8GB and are getting by just fine although admittedly I don't have any of the games the OP listed above.
 shes behine me, isn't she
Never had any problems with 16GB of RAM but if it did become a problem you could always use msconfig to temporarily limit the amount of RAM Windows works with so that it appears to applications as if you have less than 16GB.
That didn't work with a favorite game of mine. Art of War. I loved that game.
But good idea. Thanks.
Yer it was 32bit at the time, also when I had Vista 32 bit.32bit operating system though?
I have 16gb, not because I needed the extra RAM but because it was ridiculously cheap. I don't think I get more than 6gb usage but then again I got 16gb of Hyper X blue for £50.
