Better late than never, they came this morning.
Cut off the plastic/rubber coating about 6-7mm back:
For my 9 year old son who doesn't know yet but come tomorrow evening he will
Still need the karting gear, possibly a Ferrari sticker kit (he supports Alonso in F1 must to my annoyance) and trolley and then maybe something similar in adult size + a trailer![]()
What are you using the connector for??
I bought a starter kit, but struggling to find a small enough power source as its for under my kitchen cabinets.
Awesome we need more pics!!For my 9 year old son who doesn't know yet but come tomorrow evening he will
No point over here... have to drive miles for any tracks...Better late than never, they came this morning.
SNIP
I've just been mapping my kit together, the connector is used if you cut the wire to a certain length, You'll see certain points which you can cut, that cable is used to link the cut Led strip to the power supply. Haven't found any smaller power supplies, but you can buy 5050 extensions which might help you move the power supply further away.
Out with the old Pringle, in with the new Titlest StaDry Stand Bag 2014.
[/URL]![]()
Nice
So where do the cables come from?
I assumed these connectors were for having LED strip -> cable -> LED strip -> cable ... and so on
Am I right?
eBay, I think they're £10.99 now though. Search for 5050 RGB LED, and yes you're right. It's to allow for easier positioning/tight turns.
