Just this morning when I press the power button on the phone to wake it I get a resuming message on the screen for 1/2 seconds ?!?!
Never done this before, any ideas what's causing it ??
that's interesting with the charger, I am running mine via a powered usb splitter/ charger seems to work fine, but perhaps I am just being careful to check the light comes on
Most likely is that the phone and charging plate are slightly misaligned. It can cause the charging to cut out and present the issues you are seeing.
that's interesting I've had that as well, I think its heat build up as if I take the case I use off it doesn't happen. when in direct contact it works fineI think it may have something to do with the heat. The light comes on and it charges for a certain time but then it stops and the light starts blinking. Sometime it starts charging again and stops and starts, which is annoying as the screen comes on each time waking my wife or I.
Nobody elses 930 do this ?????
My freebie pack did indeed turn up today, the speaker is a lot better than I thought it would be![]()
Its really quite surprsing for such a small thing, tried it on loads of different surfaces too!
