- 22 Apr 2014
The new Samsung SSDs will be here shortly and you can pre-order your drive now with Overclockers. We will be getting the full range of 850 Pro SSDs with 3D NAND Flash. We hope to see stock land by the end of the month. I will keep you all up to date with the due date as that time gets nearer.
I will be adding more specs and speeds to the products as I get them from Samsung as well.
Samsung 128GB SSD 850 PRO SATA 6Gbps 3D NAND (MZ-7KE128BW) @ £92.99 inc VAT
The Samsung SSD 850 PRO delivers blazing-fast speeds with an exceptionally high endurance and provides the highest performance of SSDs with SATA III (6Gb / s) interface. The sequential read performance is achieved up to 550 megabytes per second (MB / s), the Write performance up to 520 MB / s The random read performance of up to 100,000 Input/Output- Operations per second (IOPS), the write speeds up to 90,000 IOPS.
Professional features for top performance
The Samsung SSD 850 PRO is not only for high performance, but also for a particularly long service life: With a daily workload of up to 40 GB, which 150 TB Total bytes written (TBW) corresponds to more than ten years, the new High-performance drives from Samsung and excellent for use in high-end PCs
Workstations based with high utilization.
These requirements comes Samsung with a Ten-year warranty for the SSD 850 PRO series after. In addition, the need Premium memory significantly less energy while increasing all performance Values??. If the "Device Sleep", the SSD 850 PRO requires just two milliwatts, which in Companies and wherever numerous PCs are durable in use, to a low power consumption contributes.
The drive also features the "Dynamic Thermal Guard "feature which ensures that the optimum temperature range and so prevents data loss due to overheating.
In addition, the drives support the Hardware encryption on Microsoft eDrive and TCG / Opal 2.0 with 256-bit AES, so Companies can control the SSDs in a network centrally.
Only £92.99 inc VAT.
ORDER NOW
Samsung 256GB SSD 850 PRO SATA 6Gbps 3D NAND (MZ-7KE256BW) @ £142.99 inc VAT
Only £142.99 inc VAT.
ORDER NOW
Samsung 512GB SSD 850 PRO SATA 6Gbps 3D NAND (MZ-7KE512BW) @ £282.98 inc VAT
Only £282.98 inc VAT.
ORDER NOW
Samsung 1TB SSD 850 PRO SATA 6Gbps 3D NAND (MZ-7KE1T0BW) @ £495.98 inc VAT
Only £495.98 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
