i just unlocked the deagle today its a fun gun for sure![]()
I love it. Just had a round where I peaked around the corner and there were 2 - few shots with the SCAR, peaked back with deagle and double kill
It really makes up for the SCARs limited mag.i just unlocked the deagle today its a fun gun for sure![]()
Been steadily lowering my sensitivity since getting the Asus monitor. Not sure if it's just the impact of higher resolution or the reduction of lag over my 120hz iiyama. That SCAR-H is a beast with angled and muzzle break. Really nice gun on sniper heavy maps.
Better than the bulldog?
The gun I've found to be Hax recently is the MPX, it's a beast!
The Bulldog is crap and has 0 range, good for close quarter maps only.
For each weapon class, are there any clear 'bad' guns, or do they all simply depend on what you prefer out of a gun? (accuracy over power etc).
For example, there's two LMGs, the LSAT and the AWS, both have exactly the same stats but the LSAT has a fire rate of 700, whereas the AWS has a fire rate of 800. Would there be any point to using the LSAT whatsoever? Surely they wouldn't make a weapon completely obsolete? (Unless that isn't the case for those without the DLC).
EDIT: And another stats comparison: RPK-74M vs AWS.
The RPK has 10 more accuracy and 7 more range than the AWS. How does that stack up against having 20 less hipfire, 30 less stability and 200 less rate of fire than that of the AWS? Do we discount the accuracy of the RPK and choose what seems to be the superior weapon (the AWS) in terms of numbers? Or do we have to weight the accuracy and range more?
What I'm trying to get at is, is there a way of seeing how important certain stats are in comparison to others? Or do we take the stats on face value and think that if one weapon has more higher numbers, that it's better?
I'll try the MPX, need a good one for assignments. The UMP45 isn't it's former BF3 self.
