Glued my first set of tubulars on the weekend. No real issues once I'd stretched the tyres to make them go on more easily. I rode out to marshall at Tameside last night and on the way back the inner tube has split where it joins the valve.Gonna see if PX will replace it, pretty disappointed.
My glue job was OK though because it was an absolute ******* to get off the rim!
Yes I was going to do that, but was just looking at makes and models that I should be looking at. Things like what the frame should be made out of, breaks, chain etc.....
Can you use Wiggle? This is one of the best deals around at the moment:
http://www.wiggle.co.uk/felt-f95-sora-wiggle-exclusive/
What are the benefits of tubeless tyres? I can understand them on a MTB where running low pressure is a benefit but doesn't seem worthwhile on a roadbike![]()
Yikes didn't quite expect those replies!
It was unfortunate I met them at a point where i was going quickly since just before and just after I would have been at a slower part of my route. I mentioned it in the office today and we have a horsey type person and she was of the mind that the horse wouldn't have been the slightest bit bothered by a cyclist (more cars and the engine noises). No harm done though.
Lower weight, no pinch flats, less prone to punctures generally. Mainly used by the pros, as changing a tubeless on a ride is a pain in the proverbial.
It's no different from changing a normal puncture really, you can just bung a tube in and your good to go.
I don't see any benefit to tubeless for road bikes. Saves the weight of an inner tube, which isn't a massive amount for the extra inconvenience of having limited tyre choices and more tricky to install.
I'd stick to tubes or tubulars but I've never ridden tubeless so there might be something I'm missing?
Finished gluing mine again with the Vittoria glue.
Ended up with 4 layers on the wheel and 3 on the tyre. Checked them tonight and they were rock solid.
I tried them with 3 and 2 layers but there were a few dry spots. 2.5 tubes used in total which is about right for new wheels I think!
When i first saw the two riders they were spread across the road but thankfully one of them went back across ahead of the other to give me room to go past. I've met horses before on the road but its normally been at a slow section so they've not really bothered when i go past, its just at this point i had a bit of speed on.![]()
On their Live Chat now, gonna ask if they accept the scheme
EDIT: They have their own scheme, doubt my work place will join there's just for me
On my last club ride a guy had tubeless, his rear wheel had a blowout and he just got the train back. Apparently the tyres are so tight on the rim it would have been a right pain to stick a tube in and continue going.
Just his tyres or is this normal for tubeless?
