- 25 Mar 2004
- Fareham
OK... Interesting! It does seem people are suggesting this solution is the most solid/reliable?
Questions:-
- What sort of spec unit should I get?
- Is it worth buying a small HD or justing using USB?
- And then I'd just need how mach ram?
- And then get a remote? Any suggestions there?
- You can turn the device on/off via remote?
As regards my need for optical output, is this the unit? - http://www.turtlebeach.com/product-detail/sound-cards-accessories/micro-ii/31
Many thanks!
I can't speak for the sound stuff as I just use my tv's connection to my soundbar for sound here.
For me a RPi is great at playing stuff, works pretty smoothly even for 1080p content over my wired 1Gbit network. Any spec NUC would be superior really as they have a lot more horse power (RPi is cheaper by far though).
Small USB HD attached would probably work out fine, you can get ones that self power from the USB, or configure a share from your PC over the network. If you are serious about sharing stuff around your networks do consider a NAS for centralized storage, they are really good bits of kit.
I don't work for Synology but it's a real dream to work with their NAS devices, I don't know about other manufacturers here.
RPi comes with enough RAM I think, not sure on RAM options for a NUC.
For remote I never use the menus, I have an app on my Android phone called Yatse that lets me connect to XBMC and play stuff (would work with either RPi running RaspBMC or presumably NUC running some form of XBMC). My RPi attached to my TV does support HDMI CEC for my TV remote though, which means you can navigate the menus with your TV remote too (pretty cool).
Yatse app here: https://play.google.com/store/apps/details?id=org.leetzone.android.yatsewidgetfree&hl=en_GB
RPi is pretty slow in the XBMC menus, but Yatse (or a.n.other Remote phone app) more than makes up for it.
I never turn off my RPi, it uses about 3-4 watts at load so even keeping it on 24/7/365 only adds a few £ to the electric bill. NUC presumably you would want to turn off it draws more power so I can't really comment on that. I have not found a way to remotely turn on/off my RPi but then it's usually on when I need it to be.
I have considered trading up for a NUC as the biggest downside of the RPi is that it can take a while to update the library, that is due to the slow CPU etc with it. Right now though the cost of a NUC just for this function has not been justified in my mind so not done it yet. I think I am maybe waiting for new gen NUC's to come out or ones that offer something more over the RPi. On the other hand a gen 3 RPi which had more CPU power would be an option too if they ever make one. I don't know how a RPi would deal with 4K content but it's not mainstream yet.
