Hi all,
I have two LG 23" monitors that I have connected to my GTX560, each via DVI.
I've been gifted a third monitor of the same make and model, but unfortunately it seems my graphics card doesn't support 3 monitors.
It's been years since I bought my last card, and given the huge choice on offer I'm concerned I'll make the wrong decision, so I'd appreciate some advice on which card to buy.
Each monitor has a DVI/HDMI/VGA input with a 1920x1080 resolution. I do play the occasional bit of BF4, but my primary use is software development/VM's. Budget is around £130, but will spend more if necessary, and I'd prefer NVIDIA.
Many thanks.
Many thanks.
