I would personally go for the Powercolour 280x
Doesn't the R9 280 still need an active display port to dvi adapter for 3 monitors in Eyefinity?
I thought it was only the 290's that supported 3 monitors without the need for an adaptor.
Just to give my tuppence, I ran a triple 3D monitor setup with a pair of 680s and then a pair of Titans and never had any issues. Adjusting bezel correction took less than 10 seconds and switching gaming on one in 2D/3D or 3 in 3D or 2D was so easy.
I can't comment about AMD but don't see either having any major hang ups in honesty.
Those Titans do look sexy!, do love those cards.
Can we and create a day's experience here for OPs requirements (no 3D).
As an example:
1. want to switch to eyefinty/ nvidia surround with bezel correction for a game of BF4.
2. enough with gaming need to do some work and switch to 2 monitors software development/VM's
3. work is a bit boring now and almost finished. watch some youtube videos also, switch to 3 regular monitors (no bezel correction)
4. work done. switch back to eyefinty/ nvidia surround with bezel correction for another game of BF4.
We could each upload this process on youtube and see in comparison of driver/ software implementation, between eyefinty and nvidia surround.
What do you say Gregster? I have a feeling my 290 will crush your sexy beasts only because nvidia surround's driver/ solution is lacking!
I know you can - I ran 3 on a 6870 with a dp to hdmi adaptor - but afaik on certain R9 series cards you still need to use the display port for one monitor, or it won't work properly ( lots of hits on google regarding this )
2 dvi + 1 hdmi won't work on anything less than a 290 I think
The op's monitors don't have dp. Only dvi, hdmi & vga.
Why would you want to turn 1 monitor off for the VM bit?surely you just don't use that monitor?
OP can get a card which has 2x DVI + 1 x HDMI outputs but they do seem to cost a bit more. http://www.overclockers.co.uk/showproduct.php?prodid=GX-347-SP&groupid=701&catid=56&subcat=1842
As an example:
d4ren, do you want to play BF4 across all 3 screens or would you just be using one?
2xdvi + 1xhdmi wont work on the 280x, one monitor has to be connected via an active display port adaptor if it doesn't have a display port on it.
