I have one of these http://forums.bit-tech.net/showpost.php?p=3659885&postcount=16 a Enermax ETS-T40 and have fitted it in this build: http://forums.bit-tech.net/showthread.php?t=276418 but as I point out here http://forums.bit-tech.net/showpost.php?p=3660528&postcount=21 the cooler is too tall by a few mill.
My question(s) are can I remove the tops of the heat-pipes without affecting its overall performance? If so what would be the best method? Would I need to reseal the pipes in some way?
__________________
__________________
