50-55 inch 1080p TV/Monitor with VGA
Caporegime
11 Nov 2002
Barcelona
Hi All,
I am looking for a monitor or TV to use for presentations. Only requirements are that it is 50 inch or over, LCD and has both VGA and HDMI. (dont need smart, 3d, 4k etc). It will need to be wall mounted, but I'm sure anything in this size range will be.
Can anyone suggest anything? Less than £1000 each ideally.
rp2000
You'll probably be wanting a commercial panel, and the new ones aren't really cheap.
You are looking at £1500+ for 50-55"
BUT, second hand you could pick up an older model dirt cheap.
Ouch, I actually don't need a commercial panel (they are better for leaving on for long periods of time). This would just be used 10/20 hours a week *less than most TVs!!). I checked some commercial ones and they are expenssive.
For maybe google hangouts and vga connected laptops for presentations or HDMI.
I guess plan B is a TV with just a VGA to HDMI cable or box inbetween, if I want to keep it below 1000.
rp2000
rp2000
Is vga a must? As you can go the dvi/hdmi route which open up a whole lot more options.
The TV should have some form of screen fit/just scan. Unless overscan is screwy on the laptop?
Toshiba TVs seem to be the last semi-decent branded TVs to still have VGA connections. I know we've sourced 47" TVs with VGA for conference rooms at work
VGA to HDMI or VGA to DVI adapter. Easy, can sort any overscan settings very easily (its not an ongoing problem you should just set it once and done if through TV).
Will save you buying an older likely inferior panel.
Toshiba 55l7453db 55" TV is available from a certain high street retailer for £899. Search for 55l7453 and it should come up.
Spec
Spec
Hi,
Thanks for that. I will look for Toshiba ones. I am based in Spain so cant use JL, but I see it for around 1100 Euros here which is the same price give or take!
rp2000
Spec
Thanks again, I have just ordered 2 of these. Hopefully they are good when they arrive in a week or so :)
rp2000
