- 8 Aug 2013
- Stoke-On-Trent
H100 ordered hopefully will drop my temps down abit compared to my air cooler
What air cooler was you useing I think your be very happy with the temps I brought 1 last year for my media box it's still going strong can't go wrong for 40 pounds
Hi all,
I'm looking on doing a new build with an i7 devils canyon and one of these Corsair AIO... my concern though is that OCUK have so many refurbs in stock; are these H100/H100i prone to breaking / leaking or something? I couldn't find any recent posts that mention issues other than people having trouble fitting them, and Google only brings up results for issues on the older H80 models from earlier years.
Also, does anyone know what the warrenty covers (new and refurb)- just the AOI itself or damage to other components if it leaked? Would OCUK replace whatever is not covered by Corsair?
I can see Watercooling is the way to go, but custom build loop is not for me, AOI is my prefered choice over fans, but I don't fancy spending £1.3k on a new build to have to replace everything on the mobo down the line if this thing fails.
Any guidance / reassurance would be much appreciated.
thanks in advance!
After having no response from ocuk my h100 after raising a ticket with corsair was confirmed as having a broken integrated fan controller. I don't know what ocuks stance is but sending my aio cooler back to netherlands will probably cost a fair bit.
Ive connected the fans to the lamptron controller and can control them from there.
Hi all,
thanks in advance!
Must admit that had me going when I got my refurb'd H100i. As Freddie says, it looks like new and runs very quiet once the initial burst of max rpm has calmed down. The pump is much quieter than my old H50. I have not yet connected the usb link, the stock hydro fans are certainly noisy at full whack but they do shift a lot of air.Bit of info for anyone wondering about the fan splitter cable, they have a cap fitted to protect the pins. (Got to redo my fans to get Corsair Link working.)![]()
