Have you tried a fresh install of windows and drivers to rule out any software problem?
I am trying to avoid having to do that atm. If it comes to it, I will do a fresh install.
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
Right, So I removed both sticks of RAM, cleaned then, put on stick on a different lane. Ran Memtest86 (no errors), then booted into windows and left to idle. BSOD.
Did the same with the other stick of RAM. Memtested it and ran windows and left to idle. BSOD.
This must mean its a driver/software error so I am now going to format the drive and install Windows 8.1.
I thought you had Windows 7 ? Are you sure you are using the correct Windows 7 drivers for everything ?
(also looks like you are not using correct symbols for windbg)
It may still be the RAM. Memtest is helpful in confirming memory error (when it catches it), but doesn't catch it all the time. Upping memory voltage slightly sometimes helps but ideally it should be capable of running at stock. BIOS updates often include helpful memory control tweaks.
Good luck in any case.
Hey guys, I have installed Windows 8.1 and happy to report no other issues as of yet. Thanks everyone for all your help.woow
Great! hopefully it remains that way![]()
I am also having this problem, when ever I go AFK my comp shuts off. if you find the answer give me a heads up!
http://imgur.com/utPrz8M
CoreTemp did make a habit of freezing windows up which doesn't normally happen but I uninstalled it and now use OCCT for CPU Temps. Is there any other CPU temperature software that warns you when the CPU gets too hot (in the system tray) and other features?
SpeedFan perhaps? Not a great UI, but awesome in ways of features
Yeah, no, ew. I think I will try and re-install coreTemp.![]()
