This what needs testing, does disabling the APU.s GPU portion allow Nvidia GPU accelerated PhysX.
I'm sure it will, NVidia are just trying block all of the 290X AMD owners who buy a low end NVidia GPU as a Physx add-in card.
Like I said you wouldn't want to disable the APU as HSA enabled programs wouldn't be able to function with it. You might also want to use it for multiple displays.
There are many reasons to leave the APU GPU enabled and installed in a system with a dedicated card.
People will just have to choose one or the other in the future, it would be better if NVidia could make it so that hardware Physx only works if an NVidia GPU is being used as primary renderer but that might be a lot more difficult or easily hackable. Or maybe that is how it works? we don't exactly have much information to go by.
According to most AMD owners on this forum Physx is rubbish anyway, plus AMD have their 'open physics' thing in development that was supposed to rival Physx.. or was that just more lip service to their users?
