Another £300 for another 290 would give me the perfect 4K gaming.
No it won't, it will give you gaming with lowered settings
Of Course you did you have 4 Titans I have 1 290, my GPU cost £300 yours £3,000.
I don't get this obsession of yours that you must have 4 GTX Titans, I have one 290, I have the same visual game play experience, don't suffer from SLI microstutter and am £3,000 better off for it.
All this seems to me trying to justify thousands of £ on GPU's where it makes no difference from a fraction of that cost, a
*foley with a purpose*.
He also has 4 290Xs.
So if there's anyones opinion to trust about running games maxed out, not working, not running correctly it's Kaap.
Nobody is trying to justify costs, infact only you bring up the costs. The costs are irrelevant and solely down to the purchaser whether it's 'worth' it.
As per Kaap's 4K threads he runs maxed out AA, at 4K, where that makes no visual difference.
I'm running Ultra IQ with just one. so two.....
As per Kaap's 4K threads he runs maxed out AA, at 4K, where that makes no visual difference. his 290X are also only 4GB cards
I agree what GPU's they like, and spend what they like, be it thousands or not, is down to them, it is not true that one must spend the same thousands on the same kit to get the same experience.
You have no idea what i use to game lol
Most of the time it is a single 290X or what ever the CF is set to at the time as that is all that is needed for Civ 5 @4K.
Having said that once you have seen 4 Titans running max settings at 4K you would take back your statements. The first thing you would notice is how smooth they are as using max settings gives the CPU a break and you don't get big dips or peaks in fps (the best way to describe it is like everything Mantle should be @4K but is not).
Some games will look rubbish whatever settings you use but this does not mean that all games look rubbish. I also find visually on my Dell 3011 and UP3214Q monitors image quality is top notch, what I find strange is people argue about settings and then game on a monitor with rubbish colours and image. My monitors are not the fastest response time but the colours and detail are superb.
If you see some of my posts with images @4K maxed it is often because people have asked me to post them so they can see what it looks like as is the case in the last 2 threads of this type I have done.
Oh come on, you don't really believe this?
do you?
A bit of advice.
Turn down the completely unnecessary maxed out AA on 4K with your 4GB cards and you wouldn't struggle with vRam issues causing FPS dips.
Either that or get some of those 8GB Vapour-X before they go out of stock if you must run high AA.
But what if he doesn't want to drop settings? AA isn't unnecessary full stop. That's a matter of opinion.
He's got no need for the 8GB Vapour-X cards when he as 4 Titans.
His choices are not everyones need.
For example..
If he had 8GB 290X, or 6GB 790Ti's he would have no need for Titan Blacks, just because he has them does not mean everyone else must have them.
I'd love to know where he'd get 790Ti's from
Although you are correct in saying just because he buys certain cards in particular it doesn't mean everyone else has to follow suit. He buys what he wants or what he needs for any given task.
I'd love to know where he'd get 790Ti's from![]()
For example..
A bit of advice.
