Tri-Fire AMD Brethren
Dragon Age 2 was one of those games that roped you in quite well with it's narrative as it's entirely spoken, but once completed you realise that you don't really go anywhere. The game is based around the same three locations.
Then when you play the first half hour of Witcher 2 it hits you. Why did I spend 30+ hours playing that ****.
@Lt(Censored)Matt.
Memory timings for 24/7 on my 3960X and Dom Plats
This will give you an idea where to start when you get tweaking.
Ignore the Dram Voltage in the pic above I think yours run @1.5v
witcher 3 is out soon?
i saw video of it, looked great
think ill try some witcher 2 thx for tip :)
or not thx if i get too addicted lol
@Lt(Censored)Matt.
Thanks Kaap, legend as always. Appreciate the sensor too. :D :cool:
Well got the board in, got the new dominators in (wow they're so heavy compared to the sammys lol) and Houston we have lift off. No issues at all this time. Straight in, back of the net as that man from Norfolk says.
Now do i reinstall Windows first or spend time tweaking and overclocking and then reinstall & activate? Decisions decisions.
Shall i update the mobo bios? I noticed it's using a newer revision than the last one, but it's still not the absolute latest. Answers on a postcard please.
you might be able to do a straight hdd/windows swap,windows will install any needed drivers
it will have a hissy fit and loop if it cant though,some chipsets you can skip to without re installing and some you cant
ive had no stability issues either when it has worked
EDIT: nvm I clicked your spoiler
My OCD will not allow that. New board, new OS comes with the territory.
ohh I hate re installing
I have all my games backed up so it's not too much of a painful process. Two hours and ill be sorted.
EDIT
Does anyone have any tips for speeding up the boot time? Takes an age compared to my P8Z77 WS.
hdd timout in bios set to 0,disable full screen logo?
any usb devices/hubs plugged in,those could stall startup
how long is long? some board do take longer than others,tried without fastboot? its flaky on some boards
cant think whatelse other than very latest bios?
mine takes 24 sec for example
