- 15 May 2012
- Louth, lincs
After replacing various high end psu's as OCP is being triggered because of pushing Graphics cards to there limit (psu power dependent) I thought i'd compile a thread of test results of my own and hopefully others, then recommendations of PSU size/power can be made depending on requirements of the user.
So today i purchased one of these
As this thread progress's i will add useful/relevant information to the OP and possibly add a recommendations table for single to multi card setups.
so to begin with, some tests, all of which were carried out on 3D marks Firestrike Extreme
3D MARK/FSX Download link HERE
Link to FSX bench thread HERE
Meter was plugged in to PC only
Please add your system specs in spoiler, excluding GPU/s like so
TEST 1
cpu@ 4.5GHz 780(classy)SLI @ stock
636W
TEST 2
cpu@ 4.8GHz 780(single)@ 1280/1750
667W
TEST 3
[email protected] 780([email protected])@ 1500/2000
841W
TEST 4
cpu@ 4.8GHz 780 SLI @ 1400/2000(1.3625v)
1395W
To work out actual power/wattage used by the PC please use the table as a guide and times your max W by your efficiency,
so in my case 1395 x .89= 1241W being used.
I did manage to run with slightly higher clocks but was getting lock ups, no doubt due to lack of power/instability, i know that on my cards i can run them individually at 1520/2027 and 1420/2027 on FSX but as you can see my psu is at its limits, so to push on i need a bigger psu or 2!!!
Thanks for taking the time and i look forward to your results
PSU RECOMMENDATIONS
Recommendations are based on test/bench results, the rated wattage figures allow for a little overhead to allow for capacitor ageing etc.
If you have NO intentions of overclocking your card and will use purely for gaming then 100w can be knocked off the stock figure.
Stock= as it says + a mild overclock
Moderate= will suffice for most users whom like to have a little bench with average clocking GPU's
Extreme= For those fortunate to own good clocking examples and who like to push to there limits.
CARD-User Level-Wattage
780-stock/moderate OC-750W
780 -Extreme OC-850W
780 Sli-stock-850w
780 Sli-moderate OC-1000w
780 Sli-Extreme OC-1500W
780 Tri Sli-stock-1000w
Titan Tri Sli-Extreme OC-1600W+
290X-Stock- OC-850W
SuperFlower 1200w Platinum
Asus RIVBE
4930k
4x4 DDR3 @2400
1x SSD
2x 18w DDC pumps
Aquaero 6 controller
15x High perf fans
Asus RIVBE
4930k
4x4 DDR3 @2400
1x SSD
2x 18w DDC pumps
15x High perf fans
TEST 1
636W
TEST 2
667W
TEST 3
841W
TEST 4
1395W
PSU RECOMMENDATIONS
780 Sli-stock-850w
290X-Stock- OC-850W
