Caporegime
- 13 May 2003
- Warwickshire
Took boards out of loft in advance of loft insulation being done on Monday.
Finished off the little man's playset and he seems to approve.
No build log just some photos here and there of progress. It came from http://www.climbingframesuk.com/climbing-frames/ and I went for the Atlantic setup which is £549 (plus I added a couple of small extras on top of that). Putting it together is pretty straight forward if you are the type that can follow meccano instructions, only a couple of times did I find a small issue where the instructions didn’t match the parts (i.e. holes not pre drilled).That is seriously cool. +++ dad points. Have you got a build log, supplier and price, etc.?
Little man doesn't know how lucky he is!
Nice work, should look good once varnished. One tip i would suggest is to do the end grain first, then if it chips a little bit you will get rid of it when you go along the grain. Also on a fairly big cut like that it's sometimes a good idea to set the depth a bit less on the first pass.
Cleaned the guttering out of moss & leaves, & cleaned all the fascias.
I need to do that. Might be a dumb question, but what type of ladder did you use?
