It has since changed. It sits on the load screen with the title and graphic of the map. It does this until I get annoyed and close bf4. No crash error or anything, just sits on the load screen.
How long is "until I get annoyed and close bf4"? The game does take a bit of time to join a server even when loading from SSDs.
If you're like me chippy and play with the details turned up I wouldn't bother with a 2Gb 770. I can max out the Vram on my 680, which causes the frame rate to drop to about 5fps. I wouldn't bother with the 4gb 770s either as they are stupidly overpriced, you can get a 290 for the same money which is a better card*.
*as long as it works![]()
Ok thanks for all the help. It appears to be a bug with MSI Afterburner, as I am now happily playing some conquest
The downside is that my GPU is running hotter as my custom fan profiles aren't/can't be used.
Set MSI to stealth mode.
Chat box was epic too.The rage was strong with towards this one on my last round of Metro.Chat box was epic too.
Let thy rapture begin, said the lord, for I am the lord, and you shall repent!
That is all - game on!
You went somewhere?
