- 11 Dec 2012
- Bangor - Northern Ireland
Hi All
Well today was Payday £££ !!!. Finally Took The Wallet out.
Currently running a system with FX-8350. So after months of debating and looking to the future, with no clear signs of improvement coming from AMD i am Moving to Intel Devils Canyon
Introducing
(Part I) Project ROG - The Beginnings
Well i have always been a big fan of the Blac/Red Builds. However, as everyone complains that they are too common. I would agree, However im sticking too it but adding some highlights in the form of some WHITE into the mix as a nice contrast.
Parts Already Received/ Keeping from Existing RIG are :
YOUR BASKET
1 x sapphire radeon r9 290 tri-x oc 4096mb gddr5 pci-express graphics card (11227-00-40g) £299.99
2 x samsung 500gb ssd 840 evo sata 6gb/s basic - (mz-7te500bw) £179.99 (£359.98)
1 x asus vn247h 24"widescreen super narrow bezel led monitor - black £161.99
1 x nzxt switch 810 ultra tower case - matt black £149.99
1 x superflower leadex platinum 1000w fully modular "80 plus platinum" power supply - black £139.99
1 x nzxt kraken x60 aio water cooling unit - 280mm £119.99
1 x asus 24x dvd±rw drw-24f1st sata rewriter - black (retail) £17.99
5 x prolimatech red vortex red wings red led 140mm fan £11.99 (£59.95)
total : £1,340.39 (includes shipping : £25.45).
parts ordered today 29/08/2014 are:
your basket
1 x asus maximus vii formula intel z97 (socket 1150) ddr3 atx motherboard £254.99
1 x intel core i7-4790k 4.00ghz (devil's canyon) socket lga1150 processor - retail £251.99
1 x avexir blitz 1.1 original 16gb (2x8gb) ddr3 pc3-19200c10 2400mhz dual channel memory kit (avd3u24001008g-2bz1) £161.99
1 x seagate barracuda 2tb 7200rpm sata 6gb/s 64mb cache - oem (st2000dm001) hdd £54.98
1 x asus rog front base dual bay gaming panel - fan & system controller £49.99
1 x nzxt front panel connections cable set 30cm sleeved - black £5.99
total : £789.53 (includes shipping : £8.00).
i have also ordered some mdpc-x psu extensions for the extra crisp clean look.
Looking into the future development (Cash Flow Depending)
(Part II) Project ROG - The Evolution To Eyefinity
(Part III) Project ROG - The Surrender to The Ice Age
Introducing
YOUR BASKET
your basket
Planned Upgrades:
YOUR BASKET
2 x Asus Radeon R9 290X ROG Matrix 4096MB GDDR5 PCI-Express Graphics Card (MATRIX-R9290X-P-4GD5) £419.99 (£839.98)
3 x Asus VG248QE 24" Widescreen 144Hz 1ms Gaming LED Monitor - Black £239.99 (£719.97)
Total : £1,590.48 (includes shipping : £25.45).
One Screen and One GPU Already Purchased !
Depending When Cash is available - If Newer Line of Cards/ Better Quality Monitors Apprear within Budget they will be bought instead
YOUR BASKET
Reserved For The Finished Project
Loop 1 (TOP CPU LOOP) = WHITE Coolant
Loop 2 (BOTTOM GPU LOOP) = RED Coolant
Will be going all out and using Monsoon Fitting and Acrylic Tubing[/SIZE]
Feed Back Welcomed
Product List
[/COLOR]
YOUR BASKET
2 x EK Water Blocks EK-D5 Vario X-RES 140 (incl. pump) £107.99 (£215.98)
2 x EK Water Blocks EK-FC R9-290X Matrix - Acetal+Nickel £99.95 (£199.90)
1 x XSPC EX420 Triple Fan Radiator £69.98
1 x EK Water Blocks EK-Supremacy - Acetal + Nickel £52.99
1 x Monsoon Hardline Pro Bender Kit 1/2 x 5/8 (16mm) - Value Bundle £49.99
1 x XSPC EX280 Dual Fan Radiator £44.99
2 x XSPC EX140 Single Fan Radiator £39.95 (£79.90)
2 x EK Water Block EK-FC R9-290X Matrix Backplate - Black £29.99 (£59.98)
2 x Monsoon Chain Gun Hardline 1/2 X 5/8 (16mm) 4 Pack - Red £24.95 (£49.90)
3 x Monsoon Chain Gun Hardline 1/2 X 5/8 (16mm) 4 Pack - White £24.95 (£74.85)
2 x Mayhems Pastel - Red Coolant 1L £14.99 (£29.98)
2 x Mayhems Pastel - Ice White Coolant 1L £14.99 (£29.98)
5 x Monsoon Hardline Acrylic Tube 1/2 X 5/8 (16mm) 4 Pack - Clear - 4x30" £11.99 (£59.95)
2 x Monsoon Chain Gun Hardline 3/8 X 1/2 (13mm) - White £6.95 (£13.90)
2 x Monsoon Chain Gun Hardline 3/8 X 1/2 (13mm) - Red £6.95 (£13.90)
Total : £1,046.12 (includes shipping : ).
Suggested Design
Feed Back Welcomed
Product List
YOUR BASKET
Suggested Design
