New Haswell E - Flop or Flip(ing great)
22 Oct 2008
ni
You've read the reviews, some of you bought the chips...what's the real world thoughts then? Outside what the media at "telling you" Do you think this round of chips are a flop or are flipping good?
I know you struggle with overclocking when you have more cores but to only get to 3.8 on a six core cpu that costs hundreds of pounds??? Hmmmm
For people with x79, it's not a worthwhile upgrade unless they just like spending the cash, then fair enough.
People coming from 1150/1155 etc it can be a good upgrade if they are pushing the high res monitors.
I'm still yet to test my 5930K as I'm waiting for my board to come, but I'm in the group who like to upgrade early and have the latest tech.
As i've said in another thread:
I'm out.
I'll wait until the next revision, or just a while for it to mature a bit. I can't justify the cost to upgrade from my 3930K on X79.
I think i'll wait for my system to die or for Broadwell-E to come out before upgrading from a 4.6GHz 3930K on X79 because at the moment, i can't warrant the spend for the performance.
5820K will probably be the CPU of choice when DDR4 prices eventually come down.
The main problem with buying into Intel hex cores previously was that the X79 motherboards were all very outdated compared to mainstream chipsets, which is not the case now.
If you already have X79 then there's probably not a big enough improvement to justify the cost but for everyone else looking at the highest end Intel it's a no brainer.
Oh dear. So I'm actually being asked what I think.
So far? not much. No one seems to have actually received their CPUs and boards, so it's really hard to tell.
But thus far it's basically a refresh of IVBE that doesn't clock as high, costs a fortune and is pretty buggy and unstable (all as I predicted).
Sadly every launch Intel have done since Sandy has been the same. 5%, more heat, more money. Yawn.
I really hope I am proven completely wrong. I've got every excuse you can name to upgrade one of my secondary rigs. But sadly the one I was thinking about is running an 8 core IVBE which could be easily replaced by a 3930k or better. I see no reason at all to even entertain anything Haswell and I hold firm on that.
I guess you could say I'm waiting on a miracle. One that deep down I know just isn't going to happen. Intel's refreshes are becoming as bad as AMD's.
So come on then. Take your chunks of flesh from the guy that just sees it for what it is and refuses to get all excited by something no better than we had three years ago.
nail on the head there....
yea, it's just another slight improvement that's useless for Gamers .
but that's not all is it because this is DDR4, so it's an extra 6 fps for a total outlay of about 550 quid.
you'll get much more performance by fitting a much faster GPU to what you have right now, be it an MSI Lightning or a 7990 off Ebay
DDR 4 is no good right for gamers only until Skylake comes along or a really powerful Broadwell.
If its no better how come all my scores in 3d benches have gone up?? Its better and the scores prove it.
IVY E spanked your SB-E also. I have 5ghz air chips.
I wanted Haswell-E to be a big leap forward but so far it just isn't especially in the hex core variants compared to X79. Have read about all sorts of issues with the new chipset to the point that some people are sending back the mobo and CPUs they've received due to the bugginess of it all.
Should improve as things mature but I personally don't fancy being a beta tester for Intel.
To be fair though Ian, your scores and CPUs (and methods of testing) are an abberation compared to the average (even high end) user.
Stick up some normal 3D bench physics scores with the average overclock (say 4.2-4.4 GHz) that most would expect on a 5930k or 5820k with reasonable RAM (and RAM clocks). Then people can start to make meaningful real life comparisons to their 4.8+GHz SB-Es and 4.6+GHz Ivy-Es. Of course the 5960X will perform better than all the hex cores. no one is disputing that.
I have a 5ghz air chip.
Look 8 Pack, I understand you're excited about X99. That's completely fine, it's something new for you to play with. However, I tend to live in the real world and run my rigs accordingly.
The fact is that since Sandybridge Intel have pretty much been dancing around the same sort of products with the same sort of figures. X79 was a true step forward, as it introduced CPUs we did not have before (6 core overclockable CPUs for example).
IVBE fitted the same socket and was more of the same. 5-10% if you were lucky.
However, back in reality you see those chips you BIN and throw to one side? they end up with us ! You say Haswell was great? most of the people I speak to thought it was awful. I've seen chips sent back because they were unable to do 4.1ghz stable with 90c load temps.
Intel have not done anything remarkable since Sandybridge. If you're into getting excited about a new socket and minimal performance increases? fine. That's what you do, that's what you like.
However, even you must be able to see that Ivybridge and Haswell were no reason to upgrade for any one?
Sure, you get the excited reviewers out there saying "Well Ivy is faster than Sandy" and "Haswell is faster than Ivy !" but back in reality they are minimal gains and really nothing to get excited about unless you are chasing world records.
So, a new chip with a new name a model number. Great for you ! you get to dig through countless samples looking for the good ones. Us? we get the crap. We don't have LN2 and we wouldn't use it even if we could.
For us Intel have released absolutely nothing new. Haswell E is just the same old technology only a little bit more of it.
Now I understand that OCUK is a business. And I understand capitalism perfectly well also. I see why you must remain positive at all times but so far with Haswell E I've seen absolutely nothing to surprise me whatsoever.
There is a massive distinctive lack of reviews for the 5820k and 5930k. All of these reviews are absolutely useless unless you are looking at the 5960x. Even the reviews we do have just quietly tuck in the hex cores then rave on about the 8 core, which just so happens to be bloody useless to a regular desktop user.
For X99 to have been great the CPUs that plug into it need to be great also. And, from what I have seen they aren't anything we don't have already. There is something very odd going on, because there is no information out there about the hex cores that people could actually afford and far more being put on the 8 core which is a pipe dream to most.
That's not how you do a launch, it just smacks of pure snobbery and is hurting Intel because those of us out there like me are not getting the information we need.
However, with the information I do have (and that's not my fault, blame bloody Intel !) the 5820k and 5930k both look a bit pants. Had Intel sent out more samples of the lower CPUs then great, maybe we would have more information than we do, but it's all been a bit of a polish for Intel to show off so far.
I moved from i7 920 to i7 4790k and am more than happy with what I have got. Not so much for the CPU, but for 6GB/s and generally better RAM options which I use for AutoCAD and a little rendering work.
I am feeling the same way as ALXAndy about Haswell-E in that they hype is greater than the real benefit to be honest. The only one that slightly peaked my interest was the cheaper 5820k 3.3GHz. And that is assuming that you do any sort of media/3D rendering as well as game.
That is purely because the cost of the equivalent i7 4790k works out at around £192.96 cheaper, so still a lot to swallow for the 2011-3 series. See equivalent specs below:
YOUR BASKET
1 x Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor - Retail £251.99
1 x Kingston HyperX Beast 16GB (4x4GB) PC3-19200C11 2400MHz Quad Channel Kit (KHX24C11T3K4/16X) £149.99
1 x MSI Z97 Gaming 5 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £104.99
Total : £516.56 (includes shipping : £8.00).
vs
YOUR BASKET
1 x Intel 5820K 3.30GHz (Haswell-E) Socket LGA2011-V3 Processor - Retail (BX80648I75820K) £299.99
1 x Kingston Predator 16GB (4x4GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit - Black (HX424C12PBK4/16) £239.99
1 x MSI X99S SLI Plus Intel X99 (Socket 2011) DDR4 ATX Motherboard £159.95
Total : £709.52 (includes shipping : £8.00).
with what I have said above and what 8-Pack states is of course both looking at the same release in different views.
Actually measuring performance in what most people are buying/using the system for doesn't seem to show the returns because we are at the point of diminishing returns. Numbers are huge but the jump in performance to the scores are not linear and this needs to be noted when people look at them.
Others such as8-pack I completely understand why they love this release. It gives them what they want and does what it says on the tin for them, with these awesome numbers and super theoretical speeds that often mean seconds or even just millisecond improvements from before. That is what pushing it to the maximum is about.
As for everyone else who is looking at gaming though, there will be little to no return at this stage and probably not for a few years.
Games developers will move to better and better multi-thread use with lower core speeds. This is the only way to move forward in the long term. Bios and Drivers will also improve over time.
What this release really does is set-up perfectly for Skylake to come along as DDR4 develops. The changes to the PC market needs to start somewhere and with the additional bandwidth DDR4 brings this may be the time that allot more consumers will start to look at APU's.
Thing is... I'm coming from an i7 920. Great chip but its getting old now. I couldnt go ivy-e, the x79 board features are old, I want what x99 has, so there's no other way to get x99 other than through the 5820k which is light years ahead of my i7 920.
Right ! so why the hell are Intel not helping people like you?
Where is a single review of the 5820k? there are none that are dedicated to it. All we've got is a bit of sloppy info from Anandtech.
I thought that after a couple of days when Intel were done showing off how great they are there would have been reviews for the lower CPUs dribbling out.
But no, nothing.
