Images of items I have purchased.
Status
Not open for further replies.
Grabbed a nice bottle from the airport on the way to Greece, saved it till I got home :). (just noticed I flipped it the wrong way lol...fail)
As posted in motors, picked up my new car on sunday, brilliant upgrade from a 1.2 Clio. Love it and have done quite a few random journeys since getting it.
It's the same 3M sticky pad stuff found on other automotive sticky holders so yes it comes off and you then simply rub away the residue. It will obviously require some effort to remove as it's very sticky and can't be re-used until you get another sticky pad to stick on.
Cheers
2 x compression tops and a undershorts for when I'm out cycling :) It goes with the 'random' gloves i posted the other day :p
But the box was like magic and contained all this, I honestly can't believe how small the spray cans are and how small the paints are and all this for like £98? :rolleyes:
Sounds about right. Paint, especially model spray paint, is expensive. You should have plenty left over for your second batch - assuming that you've remembered to buy some paint brushes. :)
Didn't you just finished building some beast if a PC not long ago?
It was an X79 motherboard fresh last year, an excuse for a case upgrade. ;) Now about to be superseded by the Intel X99 Platform which came out last Friday. Couldn't resist giving this a try. :D
Lovely car, enjoy. :)
To use with Reason 7 and the new incoming Reason 8, getting sick of the online verification junk which you have to jump through many hoops to get it working, this solves that problem straight away. :)
New trainers arrived this morning....Puma Drift Cat 6 Suede.
Mighty pleased with them as a replacement for my Adidas Racers which were falling apart. Thin sole and rounded heel for comfy driving, but don't look too trainer-ish so I can wear them everywhere :)
Status
