Having just bought a 900d and it arrived today.
Am I shocked at the such bad quality no lol.
Its not quite that bad. only 2 negative points I would make. and 1 minor
The minor is putting cards in. yes corsiar do provide an angled screwdriver, but still apain in the ass lol, just glad I don't take cards out very often
No mid plate(but you can buy a cheap one. so that can be solved easily.
Now the worst part for me is the drive cadies omg they are bad.
Whilst trying to put x2 mechanical drives into 2 of them, the small pins just dropped out off at least 5 caddies . I found them but no idea how to fix them though. I ended up securing the drives with screws( no biggie really speaking, you don't change hds that much) once they was in the caddies in the case they was fine.
As for ugly, each to there own. yes it looks like a box but that doesn't bother me, not as if I stare at it for long periods of time.
For the price I think you get a lot of case, a very versatile case(especialy for water cooling) and remember to cram all what they did for the price, you can clearly see they saved the pennies via the drive cadies. I think you should be able to upgrade them.
After owning the following cases I think its the best(for water cooling)
corsair 900d (new)
corsair 800d (still got)
corsair 650d(still got)
cooler master haf x
cooler master Cosmos II Ultra (still got)
Silverstone Raven RV01B-W(still got)
NZXT Phantom Enthusiast
BitFenix Prodigy(still got)
And a ton of other cases.
But mine is my own opion and I think the money I spent on the 900d was well worth it.
I will say this though. if the caselabs had of been available in the ul and not such bother with import duty ect I would have gone with that.
Also remember most cases have problems even caselabs, caselabs for instance have a babbit of them not aligning properly, and you have to put the screws in at an angle then straighten them up, also another problem is the power button/usb headphone mic ect not aligning properly. people have had problems with the pedastalls not aligning properly also.
so like I said most cases have positive and negatives.
It is always worth researching cases looking them up on youtube lok for reviews, unboxes.
Just my opions
