Unigine Heaven 4 benchmark
i7 2630QM. GT 525M @ 800 CORE 950 MEMORY
i7 4790K @ 4.8 GHz. GTX 780 Ti 1136 MHz Core. Not sure why my scores are lower than some of the 780s on the scoreboard.
You need to turn off the integrated graphics for the scoreboard and it could also be messing up your score when comparing to the 780s.:)
need an opinion if this is a good result for a direct cuii r9290x?
Yes it is a good score.
I just ran one of mine at the same clocks as you (1050/1350) and got 1434.
The difference in our scores is probably down to using different CPUs and clockspeeds.
Just swapped my 2500k for a 3570k and at the same CPU and GPU clocks I'm scoring 55 points less than I did before. Why would this be considering the 3570k is faster clock-for-clock plus I now have PCIE 3.0?
