Can I use GTX 780 stock thermal pads on a waterblock?
25 Nov 2007
Crewe
I had to throw the thermal pads what came with my GTX 780 Lightning waterblock in the bin because they got burnt. Is it ok to take the ones off the stock cooler so I can fit my waterblock on my replacement card?
Yeah it must have had a flame because the block has heat tint now.
It looks like I need 1mm for the VRM area and 0.5mm for the RAM, I am guessing 1mm will be ok on the RAM so I might get this.
Just be careful that the extra thickness doesn't stop the block from seating properly
Contact EK support. They are pretty good about stuff like this and might just send you another set of pads.
