OK so bit sad but I just cut up some thick cardboard to the sizes of the phones and what on earth are Apple thinking, the plus is a monster.
I have a bit larger than average hands at 8.5" (sized up for Golf club grips
) and it will be way too big for comfortable use, forget about that UI adjust thing, just holding it with one hand will be a nuisance in my opinion.
Really annoying as I wanted the better battery but unless you carry a hand/man bag around with you... I couldn't keep something like that in my jacket or trouser pocket.
The non plus seems on about the limit so will have to settle for marginal if any battery improvement once again.
Is anyone here actually interested in getting the Plus knowing how big it is? If you are and haven't really sized it up I suggest you do similar before pre-ordering one as I was thinking of doing.
