***The Vapers Lounge***
Status
Not open for further replies.
Noticed that as well may buy 2 for £30 & go for the free delivery option.
Cheers
Pretty sure my free delivery from them was next day. They chucked in 10ms of 0.3 kanthal but I was ordering more from them that time. So you might get a freebie. A lot of people like the smaller chimney for more heat on the draw.
Alright fellas, so I'm just gonna go for this and hope to get to grips with it later.
So in my basket right not I have the Nautilus Mini thing from myepack.co.uk at 18 quid. Also chucked in a mocha flavour and a tobacco flavour juice thing.
What else do I need? Specifically from that site? I'm getting a lot of recommendations of seemingly different products and all from different sites/shops. Can I not just order another 2 or 3 things from that myepack that I can receive all at once?
Thanks
Of course you can. You will need a battery too. And it would be a shame to not go for the MVP V2 from there, as they are about the cheapest place in the UK for them. Once you have that, coupled with the Nauti mini and some flavours, you should be good to go.
For a few days, until you run out of juice of course.
+1 on the MVP v2.0 shout, it's a fantastic piece of kit and you won't need to worry about extra batteries etc. I vape a lot and it's not gone flat on me as of yet.
If your budget allows, I'd get the e-liquid from elsewhere, I've sampled two of the flavours a colleague bought from there and they weren't that impressive :)
A chap on a local vaping group is selling rose V2 clones for 25 quid delivered, thought it was worth a punt at that price!
I have one here, and i am well impressed with the build quality, and the flavour beats my genuine KFL :(
Next for me is the Squape Reloaded clone, group buy going on AAEC forum for both the Rose and Squape.
Regarding clones (i know it can be a contentious issue)
But why cant the likes of Eden mods, StattQualm etc.... just outsource the production to a Chinese factory? with them providing quality control etc...
Surely this has to be the next step, and may well stop a lot of the clones.
If these can be bought in China for less than £30 surely its better for them to sell 1000 units at £60 each, then sell 100 units at £150 each :confused: or am i just being thick?
Even Iphones are designed in California assembled in China
Thats what Rip said.... Its a bit silly imo.
Beyond vape are doing it with the Beacon, thats why its so much cheaper. :)
haha, Its true though. Its clearly the way to go. Cheaper production, cheap to sell. clones will be less 'good value'
Its working for BV and the beacon. They have loads to sell. :)
Ordered the Fogger V4 this morning, hopefully it should arrive tomorrow.
I will coil & wick it at the weekend hopefully, any advice on what resistance coils to put in it?
Cheers all
Cheers all
Depends on what device/mod you're planning on using it with dude.
If you can let us know what you're going to be using, I'm sure we can advise accordingly :)
Really not bad for a clone, and even more so for only 25 quid delivered first class.
Will go with a 1 - 1.2 ohm build to start and take it from there. Looking forward to trying it out!
It will be used on either a Stingray X mech mod, Dna 30 box mod or a Cloupor T8.
Yes I like to chop and change a bit :)
My snake oil arrived this morning too!
Cheers all
Got mine coming from fasttech only £18 and I've got 2 Orchids and spare tanks in the same parcel :)
My Kayfun 3.1 clone arrived today, in a bit of bubblewrap with no accessories (no screwdriver, alan key, coil, wick or spare O-rings) does the job though, 1.1ohm vertical microcoil and it's slightly better than the nautilus.
Need to work out how to stop it dribbling liquid out of the airhole at every opportunity though.
Cheers all
I run .4 on my fogger, for me I found higher the taste just was not there. .4 is seems to be a nice sweet spot, nice warm flavour vape.
Still not as good flavour wise as the KFL+ running at .7 but plenty good enough so I can take a couple of tanks with diff flavours out with me :)
Slightly better than the nautilus? The Kayfun should kick seven bells of **** out of it
Hi everyone,
I'd love to get one of those small glass vaporizers where you put actual tobacco into it and then heat with a lighter, but I'm really unsure of the places that stock them (wish to purchase online)
If anyone can recommend an online store that is reputable I'd appreciate it .. all of these sites just look ropey and not trustworthy :p
Basically want a rebuildable with a glass tank that does not crack like the poly tank on the expromizer did, as I will be vaping my first bottle of snake oil later :)
Cheers
Status
