Just a small warning for people on forums.
Like One year ago my mate got himself xspc WC kit. And he decided to use Mayhems Black Oil Pastel coolant. All would be fine i think BUT he have not removed pressure plate from raystorm block.
Last month he called me and said.... ZEED come to Birmingham over when you have some time cause my WC kit is ****ed and does not work at all like I think it is blocked.
As I clean my waterblock each time I change coolant and hes bit of an WC noob i decided to sort him out this weekend as i was passing by.
I drained the system and noticed i cant push the coolant out even with my full power blow in the pipe. So i took CPU block apart and this is what i saw:
Even Batman joined the club LOLOLOL
took everything appart and stuck metal bits in 10% vinegear for 2 hours.
And i went 50/50 water in radiator just for one hour
Once we got back from Stake Challenge in flaming grill ( that i finished :] )
I cleaned it up with toothbrush (turned out i used hes GF one out of 4)
And back on Clean Mayhem coolant
Lesson learned Take pressure plate out if You planning to use pastel coolant
