- 5 Feb 2009
You need to enable Library view. Libraries are the heart of XBMC.
A surprising amount of options buried within the interface it seems. I'm a-learnin'...
A surprising amount of options buried within the interface it seems. I'm a-learnin'...![]()
I don't know if I've misunderstood what was meant upthread, but I was taking it that enabling library view would let me go straight into the film/TV show libraries without any intervening clicking, selecting or drop-down menus?
I can't even remember how I did it now, though, and I can't find the option now in the menu associated with adding sources in the settings options
What benefits are their of using MySQL? I know you can say pause a film in one room then carry on in another. Does this work with non live streamed content also?
Any other things?
I have a Synology nas that all my media is on that feeds a windows based htpc in living room and soon to be raspberry pi in bedroom.
Yeah the mysql db solution is great. Instantly add another xbmc box by just dropping in the advancedsettings.Xml. For example I installed xbmc on my tablet, dropped in the file and have it all up and running in a minute.
and sources.xml![]()
I like to keep my media folders clean.
IE, only videos, no NFO files, no JPG etc..
Can you use #insert synology sql client# in this way and have the DB/files stored on the network?
IE.
Say I have
\\synology\movies
\\synology\tv
(both are read only access)
Can I have
\\synology\dbfiles
(read/write access)
So all covers etc are dumped into dbfiles and used by all XBMC clients.
-I would use my NFS shares, but simplified the post for now..
No. Artwork is not stored in the MySQL DB. The best you can do is path substitution:
http://wiki.xbmc.org/index.php?title=Path_substitution
Edit: Sorry, skim read what you wrote. Yes, the above method is exactly what you want.
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>10.0.0.15</host>
<port>3306</port>
<user>DBUSER</user>
<pass>DBPASS</pass>
<name>media_video</name>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>DBUSER</user>
<pass>DBPASS</pass>
<name>media_music</name>
</musicdatabase>
<pathsubstitution>
<substitute>
<from>special://profile/Thumbnails/</from>
<to>nfs://10.0.0.15/volume2/media-artwork/Thumbnails/</to>
</substitute>
</pathsubstitution>
</advancedsettings>
Hmm, moving back to local artwork I think, it's not as resilient as I'd hoped.
Is it normal that my DB names have the following appended to them..
music46
video78
I'm new to xbmc, currently streaming BT Sports and Sky, how can I get them in HD? I have SportsDevil installed.
