- 10 Nov 2006
- Lincolnshire
Be right behind you, might be able to trade up to a ROG
People on JSA don't have £800 to spend on monitors...
Not to spend on a monitor, when you're a little older in life you have to prioritise your finances not blow £800 on a screen that sits on your desk, you'll understand when you get there, for now though you clearly have too much time on your hands, are you sure your pay cheque doesn’t come from JSA perhaps?
Grow up. I don't even live in a country that has unemployment benefits like your 'JSA'.
Don't justify your own 4K purchase by claiming those who think it is far from ready for gaming "cannot afford it".
The fact is, your own post (quoted prior), states if you had the money you would buy the ROG Swift. So less back paddling, just drop this whole "Loadsa money, look at me with my 4K" attitude.
4K has many many disadvantages along with the advantages. It's not ready for gaming yet.
Depends a bit on what kind of games you play - someone who is happy with 60Hz vsync on would probably be oblivious to the pixel response time issues, etc. and for some games of that nature the resolution can be mind blowing - the extra detail in games like elite dangerous and eve online is incredible and compared to your average typical 60Hz TN the image quality is great to.
Personally though its not a substitute for playing at 120+Hz, has severe disadvantages for fast moving FPS games online (may be less of an issue with some models) and too many games where 1:1 pixel mapping at 450dpi doesn't produce great mouse input and while higher dpi will let you get between UI elements spread out across the screen quickly you will overshoot on trying to do more fiddly stuff.
GPU requirements are actually the least of the issues I've had with it really, aside from hitting VRAM headroom a bit, aslong as you keep AA off and sometimes turn down 1-2 high fillrate demanding settings you can usually run max or close to max settings even with 1 (high end) GPU and get playable fps.
For every day use I'm happier on 2560x1440 @ 27-28", might be a different story if it was a 40+" panel - doesn't help that windows DPI scaling and most of the applications I use most don't work very well with forced scaling.
Its a very useful resolution to have but at the moment 4K is not replacing my other panels for every day use.
Hey Kaapstad,
Which 32" 4K dell did you get - just curious.
Mark
The only 4K panels I've used in a desktop PC context so far have been the 28" ones, text is incredibly sharp but also incredibly tiny :S
Very different panel to the ones I've experience of, wonder how it compares for actual response/latency.
5k is ridiculous especially at a mear 27". I have a 28" 4k monitor and that is already tiny enough of a screen for so many pixels. 4k is definitely having some growing pains as some programs don't scale very well especially with windows display scaling. Problem is you have to scale at least somewhat to not need a magnifying glass to read your screen when the screen is only 28". I can't wait to upgrade to a 4k monitor that's ~30-36" so I can feel some real screen estate that I can actually see with my eyes.
4k is very ready. It's been perfect since May, sub £500 since June and achievable without £1000+ of gpu since now the 295X2s are cheaper.
