*** The Official Destiny Thread (now includes 2.0 and TTK) ***
I think its random when you hand in a completed bounty? I'm 99.9% certain you can't pick them the same way you can with the normal bounties, no matter what level you are.
I got one today, just redeemed one bounty (not 5 as some people are saying) and got given the choice of 3 exotic bounties. Definitely Google the names of the bounties before you choose.
I have one for a fusion rifle, amongst other things you have to dismantle 10 rare fusion rifles and get 200 fusion rifle kills on level 28 enemies in the nightfall mission... :/
Ah right cheers. I will definitely look them up before accepting :D
How have you guys on here being getting on with the raids? I fancy trying it out the next time you guys get together.
Yeah, can't connect either. :(
Finally got lucky today. Spent a few hours farming the 'treasure cave' and came away with a legendary fusion rifle called 'Final Rest II' and a legendary chest piece. Also finally got a half-decent assault rifle for PvP. :)
Funnily enough the two legendary items I got were from blue engrams whilst I got a rare from the one purple engram I had. :p
Is that the cave on Earth, was just about to do that before servers went down!
Blimey that level 20 cap comes quickly, doesn't it. I thought it would take more than a few days playing.
What's the deal when you get to 20? Just finish all missions and buy better gear? I want one of those vanguard weapons but it says I need 250 marks and I only have 6, and hardly any missions give you any, and when they do it's about 5 at a time! Gonna be next weekend by the time I get a good weapon at this rate.
Yeah I was using the cave in the video. It's tedious, but I'd strongly recommend it if you're struggling to gear up as I've gone up several light levels and come away with some nice stuff so far.
Give it an hour or so each time you do it and you should come away with a pretty good amount of green and blues at the least.
I'd imagine it'll be patched sooner or later so use it whilst you can!
Im not particularly impressed with bad juju, i'm still going to grind my way to its 'String of curses' skill and its stability upgrade but I don't think I will rate it much even after that.
Maybe its just me, but nothing can beat a revolver for PvE. I will probably end up getting the FWC revolver to replace my current blue one.
I love the hand-cannons. Can 1shot most of the enemies in PvE with it.
Started a Sun Singer today. Taking some adjusting (from Hunter), but I think this will be pretty good in co-op PvE.
Concentrate on doing the strike playlists and getting your vanguard marks and rep to level 2 at least. That should let you buy some legendary gear which will quickly improve your light level to 24ish.
Public events also give you good marks to make sure to get at least 1 per day.
Or choose a faction if you play a lot of crucible. They are easier to level to 3 to buy the weapons.
Not sure if this always happened. But was about 5 of us farming it earlier for ages. Then a message popped up saying enemy's are fighting each other or some such in bottom left above super bar. Then a door to your left opened and it went crazy! Surround by loads of enemy's. Not seen it before, but we all died at some point. Not sure if it's the devs go at a joke lol. Defo woke me and my mate up.
Just got trolled by the cryptarch, purple legendary engram from multiplayer, nice level 19 blue helmet.... I wanted a purple helmet :p.
