***The Vapers Lounge***
Status
Not open for further replies.
Funny you should say that, because I've got a bottle here that I thought is rank compared to what I remember....
Don't what's happened to Vaping King's quality. Ordered some Monkey Jizz and it taste horrible nothing like when I originally bought it before it became popular.
Might be steeping time? Juices like that do taste horrible before steeping. At east ever custard I've made myself tasted yuk before a month steeping. Could be less time spent on each batch too I guess, since it is a popular juice now. Maybe the maker is having a hard time upscaling.
Been steeped for 2 weeks, also ordered 30ml of MDV666 which still taste great. Shame I order 50ml of Monkey Jizz, doesn't taste of bananas just chemically.
So I may have made a small mistake. I ordered the fogger thinking it was basically a kayfun but its dual coil. I only have an mvp 2 and the general opinion is the mvp wont be powerful enough to fire it properly! Anyone use this combo before?
Don't know what happened to Vaping King's quality. Ordered some Monkey Jizz and it taste horrible nothing like when I originally bought it before it became popular.
He was my favourite vendor for a while, probably around a year ago. I haven't used him for a long time as i've found the same as you with several of his juices.
It'll be plenty powerful enough. You just need to make sure your dual coil will have a high enough resistance build.
Aim for 1.4 Ohms and you should be fine.
I havnt even built a coil yet as I only got my kayfun last week and got 30x1.4ohm pre made coils for £5 from the guy I bought it off as it didnt cost me postage and I wanted to start using it straight away whilst I read up on what I am going to do myself
Just ordered two Kato Mirror Rebuildable Atomizers to go with my Kato box mod. I've only just found out about them :o
Do you have any Kanthal? Something like 0.2mm would be perfect, two coils like this would work. Thought tbh I think the fogger is better at sub ohm from what I've read...
Must admit, going from never making a coil to dual coiling a Fogger could be fun! :)
Saw Rips vid, he liked it. :)
Rose V2 clone now in stock in a few places.
Who what it that had one? Any good?
I have one too. It's pretty nice. Pig to build I found though. 3 times I couldn't get a 0.3mm Kanthal coil to work. Ended up with a 0.5mm Kanthal build in there which is working fine, albeit at 0.5 Ohm, which is a bit low for me for in a tank. I'm gonna try a dual coil build next with twisted ends to see if they will go in the slots any easier.
Do any of you guys every use fastech for mods? they do some brilliant ones, sorry if you do but I cannot read through nearly 500 pages lol.
A mate just bought this Mod.https://www.fasttech.com/p/1795000 and this https://www.fasttech.com/p/1738602. The quality is outstanding. They do some cracking stuff.
I have LOADS of mods from FT. Some better than others. But generally they are all pretty decent. I particularly like my GP Paps clone. Button is nice.
I have a Silver and a Black Stingray clone from them too. They are both quite nice, although the machining on the screw on the 18350 tube was a bit dire. They are sending out a replacement.
I wouldn't hesitate to buy another mod off them though. Just use China Post shipping option. Always.
Focal ecig are quite good too. I have had a few group buys off them. A Vamo V5, a Panzer and a Vanilla, and they have all been excellent, and none more than £11 delivered.
I've got the Infinite Stingray X, its great, A rule of thumb is stick with Infinite, SKX or Hcigar for clones, think there might be one or two others. Some are **** though. ;)
Tell you mate its sacrilegious putting a Aerotank on a Mech! :p
What about a dripper on one of those ego garage start up kits :eek:
Status
