** NVIDIA GTX 900 SERIES FOLLOWING MODELS IN STOCK NOW............**
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
We have the following models of GeForce GTX 980 and 970 in stock right now for immediate despatch or collection from our retail shop in Stoke-on-Trent:-
Gigabyte GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £449.99 inc VAT
The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Core Base Clock: 1127MHz
- Core Boost Clock: 1216MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: 268.6 x 98.4 x 40 mm
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £449.99 inc VAT.
ORDER NOW
Inno3D GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card (N980-1DDN-M5DN) @ £419.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
Only £419.99 inc VAT.
ORDER NOW
MSI GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £439.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £439.99 inc VAT.
ORDER NOW
MSI GeForce GTX 980 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £469.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1216MHz
- Core Boost Clock: 1317MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 500W PSU Required
- 200W TDP
- Warranty: 3yr
Only £469.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £439.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
ORDER NOW
Zotac GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card (ZT-90201-10P) @ £449.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 165W TDP
- Warranty: 5yr (2yr +3yr FREE when you register the product with Zotac within 28 days of purchase)
ORDER NOW
GALAX GeForce GTX 970 OC 4096MB GDDR5 PCI-Express Graphics Card (97NQH6DNB4UX) @ £281.99 inc VAT
Features:-
- Extreme factory overclock
- Anodized aluminum backplate protects components and reinforces the PCB
- All new Silence Extreme cooler reduces temps by up to 10C
- Silence Extreme technology switches to single fan cooling at idle for almost noiseless operation
Quad mixed-gauge heat pipes ensure maximum heat dissipation
- Copper base with solid aluminum cover
- 5 + 2 Phase enhanced power system with 8 + 6-pin inputs delivers up to 50% more power for overclocking
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- GPU: GeForce GTX 970 (GM204)
- Core Base Clock: 1126MHz
- Core Boost Clock: 1266MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin & 1x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
Only £281.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 970 G1 Gaming 4096MB GDDR5 PCI-Express Graphics Card @ £299.99 inc VAT
Features:-
- WINDFORCE 3X cooling system
- Flex Display Technology(patent-pending)
- Powered by NVIDIA GeForce GTX 970 GPU
- Integrated with industry's best 4GB GDDR5 memory 256-bit memory interface
- Features Dual-link DVI-I / DVI-D / HDMI / DisplayPort*3
- BASE: 1178 MHz / BOOST: 1329 MHz
- System power supply requirement: 550W (with one 6-pin and one 8-pin external power connectors)
- NVIDIA Surround
- OpenCL support
- Flex Connectivity (Upto 6 Monitors)
Specification:-
- GeForce GTX 970
- Core Base Clock: 1178MHz
- Core Boost Clock: 1329MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Only £299.99 inc VAT.
ORDER NOW
Inno3D GeForce GTX 970 OC 4096MB GDDR5 PCI-Express Graphics Card @ £259.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1088MHz
- Core Boost Clock: 1228MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
Only £259.99 inc VAT.
ORDER NOW
Palit GeForce GTX 970 4096MB GDDR5 PCI-Express Graphics Card @ £251.99 inc VAT
Features:-
- Radial fan blower design, better for SLI configurations and lower temperatures but at expense of being louder than NV 980 cooler and custom designs
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1051MHz
- Core Boost Clock: 1178MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x Mini-DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
Only £251.99 inc VAT.
ORDER NOW
Palit GeForce GTX 970 JetStream 4096MB GDDR5 PCI-Express Graphics Card @ £269.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1152MHz
- Core Boost Clock: 1304MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
Only £269.99 inc VAT.
ORDER NOW
Zotac GeForce GTX 970 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card (ZT-90101-10P) @ £275.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1076MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 145W TDP
Only £275.99 inc VAT.
ORDER NOW
MSI GeForce GTX 970 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £279.95 inc VAT
**1000 More Arriving Tuesday 30th September, PRE-ORDER IN CONFIDENCE!!**
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1140MHz
- Core Boost Clock: 1279MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Only £279.95 inc VAT - MORE STOCK DUE NEXT TUESDAY/WEDDNESDAY (30th September)
ORDER NOW
OcUK Reference 980 is £20 more than a branded one?
Based on our landed cost, OcUK is bought in small quantities from distributors, hence higher cost.
The brands are purchased direct in volume, giving us much better landed cost allowing us to do better pricing. :)
Buy a branded one! :)
Was hoping the strix 970 would be in stock today :(. There's a comment on you site in the product reviews for the card saying he got one as a replacement for an RMA, so how come they have been pushed back if you have stock? :confused:
RMA'd when we had stock I suspect but we've not had free stock for days. Only Asus to blame for as always under-estimating the UK market, they ship less than 100 units into the UK whereas MSI ship about 5000 cards.
Maybe one day Asus will learn how big the UK really is....................
I'm waiting on a refund for a big product i ordered from another site, then going to nab 2 gigabyte 970s, i wish the other site got a move on dammit.
You need to be quick, we've done 50 units in the last hour on that Gigabyte, predicting will be sold out by end of play today.
yep, seems like the best 970, only thing holding me off was the idea of 8gb cards, but if they are not coming soon or at a decent price, better off with the 2 4gb ones.
Free shipping code few hours after my order was placed!! How dare you :P
My order shipped today for a UPS pick up point, think i will have it over the weekend? ;)
