Unigine Heaven 4 benchmark
The higher my CPU clocks, the lower my score gets :D :p
2 x 970 @ 1478/2030
5930K @ 4.2
Wow those GTX 970 actually scale great ! From a single card at around 65FPS with a 1500Mhz/2000Mhz OC to around 120FPS in SLi with a 1400Mhz/2000Mhz GPU OC and then finally to my own 3 way SLi at 150FPS with "just" 1200Mhz/1753Mhz OC.
Another attempt with the 980 GTX on air at 185/535 offset (need to work out the clocks in the morning).
Windows 7 this time.
3960k CPU is at 5GHZ.
Not sure if this can be accepted? Took a picture on my phone as when I alt tab to save the image in paint I get a black screen, doh.
Anyway, MSI Gaming 970 at the clocks you can see above. Boosting to 1604 and memory at 8118.
4690k at 4.7GHz
4690k at 4.7GHz
Unfortunately we can not use photos as this has caused problems in the past.
