so just got new gpu, a 270x. psu is only a 430 so was aware it its more or less making it out. so to test it would be okay i loaded furmark and maxed the gpu and the cpu. it seemed to all run fine.
just there i was testing ifinite crisis and comp suddely powered off. no nice shutdown no beep just off.
i had thought it could be the cpu getting too hot with the gpu now pumping loads of heat out in te the case, was a fair warm droft coming from the top of the case. is it the psu strugling to power it all and keeling over? is there any good way to check? if it is a real problem then to go 750ti or is there a reasonable psu to go for?
