Single 980 @1516/7800
4790k @4.4
344.16 Drivers
DX11
And on the scoreboard.
4790k @4.4
344.16 Drivers
DX11
avg just delete/uninstall it.
also in the benchmarks matt posted recently it showed mantle and amd cards came out on top yet this shows nvidia cards are actually better.![]()
It shows overclocked NV cards beating stock AMD cards. Nobody has done an overclocked run with an AMD card.
Nobody has a PSU that can handle the power requirements!
But seriously, AMD game likely to perform better on AMD cards. Would that really surprise anyone?
Nobody has a PSU that can handle the power requirements!![]()
Sniper Elite 3 Benchmark Report (DirectX)
Created: 2014-10-03 at 17:18:11
Version 1.11 Build Version: 2014.09.30.004
Average FPS: 68.6
Minimum FPS: 24.9
Maximum FPS: 218.0
Number Of Frames: 5226
Average Frame: 14.576ms
Minimum Frame: 4.587ms
Maximum Frame: 40.237ms
Machine Name: HAL5
Monitors: 1
Operating System: Windows 7 Ultimate Edition Service Pack 1 (build 7601), 64-bit
System RAM: 16323MB
CPU: Intel(R) Core(TM) i7-4930K CPU @ 3.40GHz
Number of Cores: 12
GPU Name: AMD Radeon R9 200 Series
Feature Level: DX11.0
Dedicated VRAM: 3072MB
Resolution Width: 1920
Resolution Height: 1080
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Supersampling: 4.0x
Anisotropic Level: 16
Obscurance Fields: ON
Tessellation: ON
Ambient Occlusion: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: OFF
1280 on the core? Blimey Kaap!
Run that at 1440P single card and see how it compares to the results posted there.![]()
Unfortunately none of my crappy monitors will do 1440p with the cards.![]()
Created: 2014-10-03 at 17:53:40
Average FPS: 20.6
Minimum FPS: 6.0
Maximum FPS: 64.8
Number Of Frames: 1591
Average Frame: 48.569ms
Minimum Frame: 15.442ms
Maximum Frame: 165.313ms
Machine Name: HAL5
Monitors: 1
System RAM: 16323MB
Number of Cores: 12
Resolution Width: 3840
Resolution Height: 2160
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
4K result.
Single 290X @1280/1625
4930k @4.0
14.9 Drivers
DX11
Looks nice @4K too.![]()
Makes me wonder what a 290x @1330/1725 would get for score
Are this game worth to get AMDMatt?
Oh yes it does.
EDIT
You will annihilate everyone with your 290X at 1280/1625 under Mantle. Is that the 290X with Hynix memory?
Created: 2014-10-03 at 18:07:21
Average FPS: 39.6
Minimum FPS: 5.0
Maximum FPS: 871.2
Number Of Frames: 3043
Average Frame: 25.230ms
Minimum Frame: 1.148ms
Maximum Frame: 200.000ms
Machine Name: HAL5
Monitors: 1
System RAM: 16323MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Created: 2014-10-03 at 18:10:24
Average FPS: 57.4
Minimum FPS: 15.1
Maximum FPS: 578.3
Number Of Frames: 4375
Average Frame: 17.434ms
Minimum Frame: 1.729ms
Maximum Frame: 66.296ms
Machine Name:
Monitors: 1
Operating System: Windows 8 (build 9200), 64-bit
System RAM: 16327MB
CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Number of Cores: 8
Anti-aliasing: HIGH
Supersampling: 4.0x
Obscurance Fields: OFF
Tessellation: ON
Motion Blur: OFF
Vertical Sync: OFF
Stereo 3D: OFF
First run.
i7 4770K @ 4.5GHZ
R9 290@ 1030mhz core 1300mhz memory
14.7 drivers
1080P
You need to turn on
Obscurance Fields
Motion Blur
Thanks.![]()
Back in a bit !Sniper Elite 3 Benchmark Report (DirectX)
Created: 2014-10-03 at 18:30:49
Average FPS: 52.4
Minimum FPS: 15.1
Maximum FPS: 182.5
Number Of Frames: 4002
Average Frame: 19.080ms
Minimum Frame: 5.480ms
Maximum Frame: 66.096ms
Machine Name:
Monitors: 1
System RAM: 16327MB
Number of Cores: 8
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
