- 25 Nov 2011
- The KOP
Ok, would that be shown as the program not responding? That's what happens when try and run Star Swarm in Mantle.
Yeah, when a driver stops responding your game will freeze up and maybe audio skip, then you will get a black screen for couple secs and then back on again. If you force close the game down bottom you see error message about the stopped responding.
Reason I ask are you overclocking. Is because a not so stable overclock does give the TDR errors, Mantle pushes GPUs much more than DirectX so if you do have Overclock can you try running stock?
