Biggest storage available?
8 Dec 2004
Hampshire
Hello folks, I was just wondering what is the largest HDD storage available currently?
I can see the on the OCUK website that 6TB exists, but at what point does it become more economical to buy mutliples of Hard Drives rather than one BIG hard drive?
Just work out the cost per GB and get the best value one. But then sometimes its easier to have one, i always run multiple storage drives i dont like all my eggs in one basket so to speak, films on one, music and documents on another, photos on a third, then a backup drive with everything important like photos and documents.
I see thanks bud. So you recommend splitting your resources?
Can I ask how do you back up your important docs/photos etc ?
Once you get much above 2 to 3GB, it becomes as much about the backup as the storage.
I bought a synology NAS. That way I have a reliable array of disks with redundancy. Backup is to a number of 3TB disks in USB caddies.
Expensive, but in my case required due to the value of the data in question.
You should really examine the data and work out how important it is.
Last week a neighbour phoned in tears because their laptop had failed, on the disk were the last photos of their mum before she died in the spring.
I'd rather have great backups and unreliable primary storage than the other way round !
I use a program that syncs folders, and have it set to sync every few hours. This is purely to safe guard against drive failure. I also have an external drive for backup as well that also gets synced when its powered up, but i leave it off most of the time.
To reiterate Hodders you need to take into account redundancy and backup.
Redundancy
If a hard drive goes pop you want to be able to swap out the broken one for a new one without losing data and without much hassle. There are a few ways to do this but it always means duplicating data, so if you want 6TB of storage you'll probably need to buy 2 x 6TB drives.
You could buy yourself a NAS unit and set it up with RAID 1 (or 5, 6). This mirrors your data across two or more drives. I've never owned a NAS so I'll let others talk of the benefits of this.
I personally use drive pooling software (e.g. Drive Bender, StableBit). This allows you to combine the capacity of multiple hard drives into a single large storage drive. For instance 3 x 4TB drives would appear as 12TB. You can then enable duplication where a hidden copy of every file is stored on a different physical drive. If a drive fails, insert a new one and it can be populated from the hidden duplicates. This of course means that each files takes up twice its file size, a 5GB file will use 10GB of space.
Backup
Redundancy is great for if a hard drive fails but it's useless if your house burns down or if you accidentally delete something you later need.
For my important documents and photos I use cloud backup (e.g. crashplan, backblaze). This software sits in the background and continuously backs up changes to your data. This means you can restore data from any moment in time. Crashplan lets you back up for free to another computer with crashplan installed (e.g. to a relatives PC) or to their cloud for a paid subscription ($5/month).
There are lots of ways to do this, that's how I did it :)
And finally, to answer your original question buying 2 x 3TB drives may save you ~£20 over buying 1 x 6TB drive, but for that little difference I'd always prefer having the higher capacity to keep my case less crowded.
Thanks for your response. When you say "above 2 or 3GB" you mean if you have that amount of data, you should be looking to backup?
When you say you have an array of disks do you have multiple HDDs in your Synology, each HDD backing up? (i.e. multiple redundancy?)
Fully agree with your comments by the way to backup.
Where do you sync up to? Whats your medium? And what program is it you use to sync?
I have a total of 1 backup HDD in my pc and 1 external. Not sure what the program is but there are lots out there if you search.
The UltraStar He6 is a 6TB drive. That I think is the largest.Or it was last time I looked.I did read Seagate will be bringing out 60TB drives, but that will be a while.
Rechecked and there are 8TB drives out now. UltraStar He8
Hmm thanks all for your input. So many options to do things.
Whatabout lets say.. SSD as backup? Is this viable? Lets put it this way what is more prone to failure? SSD or HDD?
SSDs should be less prone to failure but the cost per storage means it's not really worth it. You're looking at £150 upwards for a 500GB SSD, for the same price you can get 3 x 1TB HDDs!
I have 12TB of storage but no redundancy as I back everything up to Livedrive. In the event of disk failure, I would restore from the cloud.
I heard that 10TB will be available within 12 months :)
I have a 6tb drive in my Synology. Also keep copies of this data on other drives, 2x 4tb drives which spend 99% of the time offline.
Along with a drive pool https://stablebit.com/ containing 3x 2tb drives. This is basically a very basic software jbod RAID, if one drive fails, the other drives have the remaining data on them in an easily recoverable way (hidden folder).
How big is your One Drive account? :o
-edit, didn't realise it wasn't an MS service.
