Permabanned
- 30 Aug 2009
Dont remember how much deionised water and coolant I need to add.
is it 10% then 90%??
all tubeing and compression fittings are tight???
Just to double check, which end of the monsoon fittings did you put the o-rings on?
The only way possible, those monsoon fittings screwed ontop of the Grey o ring fttings.
Kind of lost track a bit here o rings are those that block waterpathways?
If so i was refering to the hose extension on the putmp that attaches to the compression fitting
