***The Vapers Lounge***
Status
Not open for further replies.
Gonna have some fun tonight, Meet the Mutation X RDA. :)
Around £18 for an authentic, high end dripper. I have to try it....
(Yes I know, the Stingray needs a clean....)
Dumb question:
I guess it's normal for my liquid to go darker quite quickly when it's in my tank? Something to do with the oxygen reacting with the Nicotine or some such?
Also, one thing I've wondered... I guess I can clean the tank easy enough by stripping everything apart, but how do I stop flavour bleed when I change juices? Is there something I can clean to stop this too? (Nautilus mini)
My new Kanger IPOW 2, 1600 mAH variable watts battery arrived today from Vaper Store. As there isn't a lot of info on these yet I thought I'd post a few pics.
I can see where the confusion on whether it's 12w or 15w comes from. This is the box:
and this the instructions:
It is definitely 15 w though:
(ignore where it says 9.9 OHM, no tank on device)
And here it is next to a Spinner 2:
I haven't given it much of a test yet as it only arrived a little while ago but so far I like it.
Dumb question:
I find when my juice discolours (goes darker) and I don't get a decent vape it is time to change the coil. Mine generally last about 3 weeks before needing to be changed.
As for cleaning, I use hot soapy water and then rinse everything through before drying and re-assembling.
The vape is absolutely fine, and if anything the flavour is still getting stronger so I presume it's what V_R is saying :)
Exactly, I've got a bottle of GVC at home, been steeping since June, you should see the colour of it! Needless to say it tastes amazing. :D
I've got a few bottles that I ordered from Chef's Vapour, I want to vape them now they smell so good but need to clean everything out first. They've only been steeping since Monday too. I think they're going to be in a different league compared to the basic ones I got from Vape Escape with my kit!
Fair one. I find after 3 weeks with the same coil, I get to actually taste the juice (like it is seeping through) and I find the liquid changes colour (darker) very quickly. I no longer get a good vape but a horrid taste but a coil change sorts it.
I'm looking for an atty for tasting juices. I've got a fair amount to go through. I've got 2 Kayfun Lite Plus that I use for my day to day juices, and a protank2 which I'm not convinced that I get very good flavor from. Can anyone advise something?
I have an igo-W (Plus) not entirely satisfied yet... but need to play with it a bit more.
Tried a dual coil with 1.4ohm build. Was too hot and took a while to heat up.
Tried a single coil 1.4 ohm build and it's ok. But i feel like im wasting potential with it.
Any other builds I can try? Quad or perhaps serial builds work?
Might close one of the air holes too... draw is too airy for my liking.
Try one hole blocked so your single cool gets all the air over it. That seems to work well for me. I just poked a toothpick in and snapped it off. I have drilled the open hole out a bit bigger though
Gorgeous RDA, I hope you're on commission with angelfiremods and it's just promped me to order one! :p
14.50 or so with the POTV10 discount applied.
Where did you get the IPOW2 1600mAh? And is that bottom pic with an Aspire Nautilus Mini?
Looks great seems to fit it perfectly.. Am in the market of the Nautilus Mini and this battery looks a great match for it.
I bought it from http://vaperstore.co.uk/
It's not on their website yet but they have a few in stock if you email them.
The reason I wanted one was to add to a Nautilus mini to have something subtle when in a pub etc. Very pleased with it.
I paid £29.95 delivered.
Edit - yes they are both Nautilus mini's in the bottom pic.
Got mine from - http://innovapours.co.uk/index.php?route=product/product&path=39_62&product_id=431 :)
FFS I always forget the discount codes...... :(
On the plus side it's a great RDA!
This is what I did tonight:
Dual 2.5mm ID coils, with .37 kanthal (27AWG), 9 wraps = 0.5 ohms, 30ish watts, and yes thts Rayon, I know I said I didn't like it but this is from The Vape Mesh Company. The original stuff I had (the 'Graham Celucotton' from Ebay or C9V - white and blue logo) was the stuff that squeaks in your fingers this stuff is far more like normal cotton.
Liberty Flights have commissioned a survey "The Big UK Vapers Survey"
Liberty Flights said "We are pleased that UK Vapers have kindly agreed to support us by promoting the survey on their forum. We need to hear from you, the British vaping community, about how vaping has really affected you, your life and your fight to rid yourself of the deadly cigarette.
We’re hoping it could be the biggest survey of vapers ever conducted in the UK – providing new revealing statistics on everything vape-related. We believe the survey will finally give voice to the real story of vaping, debunk many of the common myths and misinformation and stir up real interest among the national media.
Every vote counts so make your voice heard and take the survey.
THE SURVEY IS HERE: https://www.surveymonkey.com/s/KXF7MC9"
UK Vapers Admins would like to stress that the decision to support this survey involved no inducements of any kind and implies no endorsement of Liberty Flights. We are doing this because we feel the exercise may prove useful to Vapers and it has been agreed that, once Liberty Flights have analysed the results and made their own announcements, the raw data will made available to UK Vapers for use and analysis by others.
We would encourage UK Vapers members to take the survey.
http://ukvapers.org/Thread-National-Vapers-Poll--79784
Status
