I have a titan SDS which I abuse the absolute crap out of, I've used it for core drilling and breaking and all sorts of uses it wasn't made for and it's great, I've got a makita SDS which is better as a unit though, more powerful, more efficient. And that is the SDS I use as an SDS.
Overall though I'm a Makita whore, I have a makita belt sander and it's a good bit of kit - would recommend if you're after a good belt sander. I've used it for carving out guitar bodies and necks and it's been a solid performer, the cheap ones usually don't last after that kind of abuse.
I've got some Milwaukee 12v stuff, a little 1/4" drill driver and a "hackzall" both of which are cracking bits of kit. Lighter than most of the 10.8v tools I looked at before and very cheap for what they are.
I've tried the evolution rage saws and they're amazing value for money, they're not as accurate cutting as a metabo or a makita but they're damn near and ideal for DIY projects. The blades are reportedly incredibly for metal cutting as well.
Fits nicely and now means I can use all my standard bits on the SDS drill - although you don't use it for hammer (because that's the whole reason for SDS!).
