- 29 Dec 2012
I got my i5 3570k and msi z77a-g45 motherboard yesterday. For now i have just set the bios to Oc Genie mode which overclocks the cpu to 4.2ghz with no effort on my part since i am inexperienced with overclocking.
I noticed when i got it that the cpu would clock itself down to 1.6GHz when idle but since enabling oc genie it no longer does this. I thought it was called speedstep and this is enabled in the bios. I would ideally like this feature back since it saves power and i suppose it helps the cpu last longer.
Does anybody else have this motherboard or one with the same/similar bios that can help me with a proper OC and to get the clock down to work again?
also are these temps any good?
idle = 30°c ish
full load for 2 hours = 60°c ish with a 4.2ghz oc genie overclock
thanks,
smithy
idle = 30°c ish
thanks,
smithy
